Loaded trailer leaning to the side?
Discussion in 'Questions From New Drivers' started by DAX_, Nov 22, 2019.
  1. DAX_
    DAX_ Medium Load Member
    603
    503
    Sep 4, 2017
    So I just picked up a load and the loaded trailer is leaning to the side. Like it's gonna tip over or something. The trailer was not sealed so I go inside to see if anything fell over and nothing was fallen over. I have no idea why it is doing this but I do not feel safe driving with the trailer like this. Is this a reason to turn down the load?
  3. 12 ga
    12 ga THE VIEW FROM MY OFFICE
    1,568
    1,789
    Oct 21, 2013
    Central Michigan
    Then don't pull it. Something goes wrong it's your fault, on you not the dispatcher.
  4. wsyrob
    wsyrob Trucker Forum STAFF Staff Member
    5,769
    5,463
    Sep 14, 2007
    Winston Salem
    Check it for broken springs
    D.Tibbitt, 86scotty, okiedokie and 5 others Thank this.
  5. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Sounds like broken spring or blown airbag.
  6. AModelCat
    160,447
    Loaded heavy on the low side?
    truckdriver31 Thanks this.
  7. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    could be broken springs, could be bad air bags, could be a cracked axle sub frame....we cannot see it, but you can, maybe take pics and post them..??
  8. DAX_
    603
    503
    Sep 4, 2017
    Imgur
    truckdriver31 and Lepton1 Thank this.
  9. ZVar
    ZVar Road Train Member
    10,911
    23,829
    Sep 10, 2010
    Flint, MI
    Hook it up, could just be air bags are empty and one has a different low air limiter than the other.
    Now if it's still leaning after giving it a couple minutes to fill air bags, then yes get it fixed.
  10. buddyd157
    13,576
    34,885
    May 25, 2017
    under a shade tree
    in that pic, you ain't even hooked up yet, it could be a bad landing gear.
  11. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    Did you hook it yet? You might be okay once it's on the truck and aired up.
