Loading excavators, big cherry pickers, tracked vehicles, forks-best place to see how to drive them
Discussion in 'Heavy Haul Trucking Forum' started by Doing_flatbed_nc, Mar 19, 2016.
  1. Doing_flatbed_nc
    Doing_flatbed_nc Medium Load Member
    585
    846
    Mar 3, 2016
    I recently took a local job working at a tow/ equipment moving company.
    After 5 days of ride alongs learning towing, heavy equipment tie down, and things like winching containers onto rollbacks, I was thrown to the wolves.
    Last night I was sent to a construction site to pick up a crated crane. Got there and no forklift drivers in site (Friday night).
    Dispatch walked me through starting up a HUGE forklift. I played with it for a minute and then drove it to the palleted crane and managed to load it on my bed. My first time in a forklift and it was one that steered all four huge tires.
    Secured the crane with chains and delivered to another site where everyone had gone home. Dropped and tilted the bed thinking it would magically slide off. Nope. Had to chain the pallet to a pole and pull it off.
    Then I picked up a monster boom crane. Somehow, I managed to get it started and drive it on my bed while raising the bucket to keep it from scraping.
    This job is going to be all about moving loading and unloading everything from scissor lifts to oversized excavators.
    What's a good resource to learn to drive individual equipment? By drive I mean start and move onto a bed.
    Luckily, everything I've messed with has been operated via joystick. Are the ones operated with levers and foot pedals hard to drive?
    Anyway, this is probably the most interesting job I've ever had.
  3. TheDude1969
    TheDude1969 Heavy Load Member
    807
    823
    Jun 10, 2013
    Joliet, Il
    youtube, operators manual, and common sense will be your only friends. Finding the dead man switch, to start the darn machines, on all the different makes was my hardest part.
    The only suggestion I can give you is keep everything/everyone away from you while you learn each control, including the foot pedals which are not that hard. <--Common sense and good luck
    Doing_flatbed_nc and Mudguppy Thank this.
  4. Biomagnum
    Biomagnum Light Load Member
    68
    135
    Jun 7, 2013
    It also helps to have the operator load the equipment for you if possible while you watch, or give you some pointers while you do it. Most of the time though you are on your own. Be slow and careful and don't let anyone rush you.
  5. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    Both good answers. ^^^^
    Also, if nobody's around to give you pointers, once you get a new machine started, run it around (off in an empty area ) for a couple of minutes to get somewhat familiar with the controls before you start trying to run it up your trailer / bed.
    Good luck and take it easy!
    Doing_flatbed_nc Thanks this.
  6. realdesertkickin
    realdesertkickin Heavy Load Member
    925
    752
    Nov 18, 2013
    Tustoned Arizona
    Ya, when you approach a new machine, take notice of your tie down points and start the thinking process right away....getting it where you want it the first time is priceless..
    Your tie down points will usually be your determiner on positioning...
    I hate big front end loaders the most, they bouncy bounce making chains loosen, then tighten again...I like dozers and asphalt pavers, they sit like a slab of steel and never move...sometimes only throw chains on for looks, if just going across town..
    Great job, decent path to be an operator!!
    Try to not scratch off the paint with your chains!! LOL
  7. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Yeah, sorry to say it's a hands on learning experience. But, it's a very rewarding one as well. It's pretty cool to drive some of that stuff.
  8. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    Yes. I started with an OTR flatbed company thinking it would be hands on.
    driving a few hundred miles, tarping, unstrapping, waiting to get unloaded was not enough hands on.
    Now, in one day, I can be in up to four different vehicles, loading and unloading containers, heavy equipment, and pulling upside down wrecks onto a rollback.
    This is definitely hands on and a lot of fun.
    But, I realize with all this different action comes a ton of risk. I have to move slow and double check everything and pre-plan like and re-plan.
    I love it.
  9. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
    Reason for edit: Personal info exposed
  10. Doing_flatbed_nc
    585
    846
    Mar 3, 2016
  11. TripleSix
    130,123
    Just name the machine you need help with. Guarantee one of the guys on this forum has loaded and pulled it and probably has pictures.
    Mudguppy, MJ1657, Oxbow and 1 other person Thank this.
