Loading Quad-Axle Trailer
Discussion in 'Canadian Truckers Forum' started by Mr_Logistix, Nov 25, 2010.
  1. Mr_Logistix
    Mr_Logistix Bobtail Member
    We are utilizing BR Smith 53' quad-axle trailers for deliveries to Montreal from Toronto. The loaders are leaving 4 feet in the back where 2 skids could still be loaded. Anyone know why they may be doing something like that? I do not have access to anyone at the facility. Thanks
  3. FLATBED
    FLATBED Road Train Member
    1) Whats the reason for using the TRIAXLE trailers.
    2) How heavy is your product.
    Could be they reach the max weight with space still available , better to leave the space at the tail of the trailer than at the nose.
  4. Mr_Logistix
    The commodity is beverage. The weight tops out at 81,000lbs, the quads are good for 85,000 lbs, leaving 4,000lbs available.
  5. FLATBED
    Max weights in Ontario / Quebec for TRIDEM is something in the area of
    12000 Lbs steers , 39,600 Lbs drives , 52,800 Trailer for total gross of 104,500 Lbs with Max payload 65,000 Lbs
  6. Flying Finn
    Flying Finn Heavy Load Member
    972
    556
    Jun 22, 2010
    Ontario, Canada
    If I understand where he is coming from, they are using quads because the load weight is #81,000. A tridem wouldn't work for that situation. At least that is what I think he is saying.
    What are you registered for, gross Kg's? If the weight balance is good and adding two skids on the tail wouldn't put any ONE axle over then it may just be a loader that doesn't quite understand what you can load.
  7. Prairie Boy
    Prairie Boy Road Train Member
    3,258
    1,913
    Nov 18, 2010
    Edmonton, AB
    Ontario gives you 18,000 kgs. on the drives ?????
  8. Bikerboy
    Bikerboy Light Load Member
    299
    183
    Apr 1, 2008
    Canada
    maybe hes got a 72 inch spread tractor
  9. bulldozerbert
    bulldozerbert Medium Load Member
    622
    240
    Oct 5, 2008
    Ontario
    who knows? Maybe the shipment amount does not fill the trailer? And quad is four axles, not? A tridem would be three axles.
    other than talking to the shipper, your guess is as good as mine.
  10. TheHealthyDriver
    TheHealthyDriver Heavy Load Member
    837
    274
    Jul 11, 2010
    Stony Mountain, MB
    Ontario is like Michigan, where you can run more than 3 axles, which is why he's running a quad-axle.
    As for why they're leaving the room at the back, maybe it's because that's all there was for that load.
    And yes, ON and QC allow 18000kg on the drives.
  11. end of the road
    end of the road Heavy Load Member
    868
    540
    Jul 4, 2010
    Northern Canada
    Tell the shipper to leave that space part way up the trailer and when you go to unload you will see why.
    First time you touch the brakes the pop will be all over the place. Especially the plastic bottles. Even cases of cans are prone to spillage.
    However, if he skids are that heavy, you are likely overweight on the drives if they load it the way they are. You need to load 1,2,1,2 and then 2 the rest of the way up. Does that make sense the way I am explaining it?
