Local log help.
Discussion in 'Experienced Truckers' Advice' started by soon2betrucking, Aug 9, 2014.
  1. soon2betrucking
    soon2betrucking Road Train Member
    1,658
    473
    Sep 28, 2007
    Philadelphia, Pa
    Ok guys, need some help with logs.
    I have been doing local now for a few years and recently took a position that sends me 200 miles out, 200 back.
    I have to log I know, however my problem is this,
    I work 7pm-7am, my round trip runs about 422 miles, that's simple, the problem is that my trucks takes the same trip from 7am-7pm. So at midnight I put down starting mileage for that day, then again at midnight the next nigjt I have to put ending mileage, which shows my miles along with the other driver, a total of 844 miles on my log.
    How is this done? I can't show that I drove 422 miles more than I actually did?
    Our logs, paper for now, are set up with beginning and ending mileage.
    Anyone i talk to isn't entirely sure... so I'm hoping for some insight from anyone.
    Thanks in advance
    -s2b.
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I'm not going to tell you that what I do is 100% correct,.. but its what I do and DOT has never questioned me about it, So I assume it must be ok.
    I'm OTR, but at times when my daily HOS crosses midnite and into the next morning, I dont break up my mileage for each day. I carry the mileage for the 11 hours of driving time and show it at the end of my run. Say I start 7pm and run till 5:30 - 6am. I average anywhere from 650 - 730 miles. So say I show my PTI on the 8th and sleeper berth /rest on the 9th,.. the mileage for that trip goes on the 9th. The mileage on the 8th would have been for the previous trip.
    I know this is not always ideal and various situations can throw a monkey wrench into things. But right or wrong,.. thats how I do it.
    Also,.. what I have done in the past when I needed to keep track of my daily mileage,.. I had multiple trip meters. I would start one after I did my PTI, then at midnite I would start another and subtract the mileage from the second to show the mileage for the previous day. Or, you can just pull over and write down your odometer reading at midnite and go from there if you want to break it up that way.
    Hurst
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    I always ended my logs at midnight with mileage and then started the 0001 log with the ending mileage of the prior day.
  5. zenaddler
    zenaddler Light Load Member
    158
    130
    Nov 7, 2013
    I would just include the morning endings miles in comments to show what you did. When in doubt use comment to make it make sense.
  6. morlandoemtp
    morlandoemtp Light Load Member
    185
    95
    Jul 5, 2014
    New York
    Get some night log books, easiest fix. Or you can track your milege if you have a gps or want to reset your milege on your dashboard, you can set an alarm on your cell to remind you and see the mileage you have driven thus far.
    soon2betrucking Thanks this.
  7. Allow Me.
    10,745
    12,479
    May 28, 2009
    Rancho Mirage, Ca.
    It seems to me you log your driving shift, which includes your hours worked/driven and miles driven with start/end times. 7PM-7AM, you drive 422 mi, logged 12 hrs etc. The day shift guy has his own log book and what he did doesn't affect you and your shift.
    soon2betrucking and Hammer166 Thank this.
  8. postmandav
    postmandav Medium Load Member
    313
    90
    May 18, 2008
    south portland, maine
    I seems to me that you are trying to use a logbook for two different drivers. Each driver should have his own log book.
  9. Ridgeline
    22,652
    120,939
    OK.
    OK - 12 hour day.
    What problem?
    Nope wrong.
    YOU need to put down the mileage that you use the truck for. YOU can put in the comments section the starting and ending mileage for the two shifts but your total mileage has to be for that 24 hour period.
  10. jamesa
    jamesa Bobtail Member
    If you start at 7pm on the 15th then your log should show you off duty until 7pm. At midnight, or at the next point you take a break after midnight you should start a new log for the 16th. On the 16th your day ends at 7am. The other driver needs to fill out a completely different log.
