Location of the CAT C15 engine block heater?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Ciufero, Jan 22, 2019.
  1. Ciufero
    Ciufero Bobtail Member
    19
    Dec 29, 2018
    Where is CAT C15 engine block heater located ? any picture, diagram
    How do i check it ?
  3. Do you have the plug under your driver's door?
  4. kwforage
    kwforage Road Train Member
    1,047
    472
    Jun 3, 2007
    Wisconsin
    It's on the passenger side, to the rear of the oil cooler.
    Ciufero and Oxbow Thank this.
  5. ODR
    ODR Light Load Member
    66
    48
    Sep 30, 2013
    Tompkins, Sk
    To check it. Once you find cord and plug it in listen for a quiet sizzling sound or if there is lots of background noise get it awhile and put your hand on it to see if is making heat.
    Ciufero Thanks this.
  6. Chipperrr
    Chipperrr Light Load Member
    58
    10
    Nov 27, 2018
    In the oil cooler??
