Lock Cylinder
Discussion in 'Volvo Forum' started by mecho57, May 2, 2015.
  1. mecho57
    mecho57 Bobtail Member
    23
    8
    Feb 9, 2008
    Clemson SC
    Morning, I bought a new ignition switch for my 06 volvo 780 as the old one seemed to be a little flakey. I need to install my lock cylinder into the new switch. Plez tell me the secret removal technique. Thanx.
  3. EHB
    EHB Medium Load Member
    491
    209
    Apr 26, 2011
    Newfoundland
    This may NOT be for 06 volvo 780 but it gives you an idea what is involved, a lot of messing around.
    Locksmith Volvo Ignition Service - YouTube
    https://m.youtube.com/watch?v=TzUduzjR9W4
  4. mecho57
    23
    8
    Feb 9, 2008
    Clemson SC
    You're right,That is not an 06 volvo switch, Mine is much simpler and has 2 holes already in the housing.I suspect the lock cylinder is held in with a spring clip. I have changed lock cylinders in other vehicles and the key had to be inserted and rotated to a specific position to allow release. I don't want to damage the lock cylinder trying to remove it in the wrong way. Most of these things are ez if you know the technique for removal,If you dont, You break it.
  5. mecho57
    23
    8
    Feb 9, 2008
    Clemson SC
    Figured it out. Remove the ignition switch from it's mount plate.Unplug the wiring.Holding the switch in your hand,insert the key,turn the key to accessory position.look into the hole in the body of the lock cylinder recess. The hole in the smooth rounded side of the body not the one in the flat.Push in on the key and look for the copper colored spring plate sticking up, Push this plate down with a small punch and pull lock cylinder from the switch. Line up the pins on the bottom of the lock cylinder with the recesses in the switch and push the lock cylinder in. Should lock into the new switch easily.Hook up wiring,Reinstall in mount plate and done. Thanx for your help.
    poniikyanion, disoba and 25(2)+2 Thank this.
