log book question
Discussion in 'Questions From New Drivers' started by erniebass, Sep 4, 2013.
  1. erniebass
    erniebass Bobtail Member
    7
    #1. What will keep me from having to keep a log as a otr driver ?..... #2. Do I have to keep a log if I stay within 150 miles of my terminal ????
  3. chopper103in
    chopper103in Road Train Member
    2,407
    6,562
    Apr 11, 2010
    Crossville,Tn
    no log if within 100 mile radius of home terminal, any further and you need a log
  4. erniebass
    7
    thank you for the answer
  5. smolfri
    smolfri Bobtail Member
    10
    8
    Sep 4, 2013
    Central Ontario
    You do not need a log book within 100 "air miles" of your terminal. However you still have to have a signed schedule 1 inspection sheet as well as a punch card with your start time stamp on it. Even though you are not keeping a log you are still required by law to follow the same laws and procedures To stay with in compliance
    Pmracing and chopper103in Thank this.
  6. ewill71
    ewill71 Heavy Load Member
    759
    234
    Oct 3, 2011
    mcgregor tx
    I believe "100 airmiles " is about 107 ground miles..... its been a while I think I am right.
  7. smolfri
    10
    8
    Sep 4, 2013
    Central Ontario
    It is certainly within that range. It is a good thing that the FMCA Specifies that its air miles and not just miles Otherwise DOT Could put you out of service if you put over a hundred miles on the odometer in the day. Even if you were just driving around the block for 2 hours.
  8. wis bang
    wis bang Road Train Member
    3,409
    4,027
    Jan 12, 2011
    Levittown, PA
    114.63 statute miles = 100 air miles
  9. KMac
    KMac Road Train Member
    3,427
    3,067
    Jan 26, 2012
    Waxahachie, TX
    Good Lord that would have to be a big block:biggrin_2559:
    smolfri Thanks this.
  10. smolfri
    10
    8
    Sep 4, 2013
    Central Ontario
    Lmao i guess it would be a Texas block :biggrin_25524:
    KMac Thanks this.
  11. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    It can be done... with this truck:
    and you catch all green lights!
    Mikeeee
    smolfri and KMac Thank this.
