log book
Discussion in 'Trucking Industry Regulations' started by Taunter, Nov 6, 2012.
  1. Taunter
    Taunter Bobtail Member
    16
    Oct 18, 2012
    wayne nj
    Do you need to carry a log book if ur driving for ur own buissness ? with a tractor and a trailer ?? Moveing equipment for ur self ?
  3. Numb
    Numb Crusty Curmudgeon
    4,231
    9,926
    Jan 30, 2012
    Charlotte, N.Carolina
    are you driving long distance or local, ( 120 air mile radius) ? commercial plates and a DOT number ?
  4. Taunter
    16
    Oct 18, 2012
    wayne nj
    have to rent a tractor to drive from jersy to chicago ill to move my own equment straight job we have not big enough
  5. fortycalglock
    fortycalglock Road Train Member
    6,159
    6,598
    Jun 25, 2011
    Tourist Town, FL
    You'll need a logbook for any CMV over 10,000 lbs
  6. Taunter
    16
    Oct 18, 2012
    wayne nj
    thanx for the info now i no
  7. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
  8. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    "Business" implies commercial use, whether it is your business or not. Commercial means the feds can regulate it if you cross state lines, and T/T's are heavy enough that you'll fall under the HOS rules and regulations. You will have to maintain some form of record of hours worked in compliance with the regulations.
    I've never heard of a 120 air mile radius rule. The "local" exemption for log books is a 100 air mile radius. An air mile is the same as a nautical mile, NOT the same as a land mile. 100 air miles is the equivalent of 115 land miles.
    Then yes, you will be required to have a CDL, log book, stop at all of the scales, etc...basically abide by all of the regulations that every other semi truck on the road has to follow.
  9. Marlin46
    Marlin46 Medium Load Member
    504
    299
    Mar 17, 2010
    Atlanta, GA
    Sounds like it would be less expensive to hire this out...either a power only job if it is your trailer or t/t if you didnt have a trailer....between renting a truck from Ryder and the fuel....and you are spending a day + to do this why not sub contract it out. Not telling you how to run your business however from a cost standpoint you are really cutting it close as to if any savings exist.
    Again - I do not know the exact situation so maybe you could elaborate a lil' more?
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    This might help you taunter
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=395.8
    http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?reg=395.3
    On your trip you can drive 11 hours in a 14 hour period than you must take a 10 hour break. In the first 8 hours of driving you must show a 30 minute break.
  11. Taunter
    16
    Oct 18, 2012
    wayne nj
    thanxs all for the input we have equipment that has to be ran out and droped for ajob but the straight job we have might be to small i have a class a lic was thinking of renting a truck and trailer to do this just not use to log books i no it will take two days to do it alown with laws and rest time i can drive the truck and trailer i just dont do it all the time.
