log books
Discussion in 'Questions From New Drivers' started by mjnkjn, Aug 6, 2009.
  1. mjnkjn
    mjnkjn Bobtail Member
    15
    rockford,il
    When you start your day and do your pre trip you write in the time and city were you start then when do you fill out the rest of the day ??????Is it at every stop and do you have to keep track of miles when you drive??? or cross the boarder into another state??? This is the first time I had to use them My last company had electronic logs ??/ Whant to stay safe and not get any unexpected tickets from DOT???? My company dispatch is not sure he has never been a driver>>>>
  3. Raezzor
    Raezzor Quis custodiet ipsos custodes?
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    FMCSR states you have to update your log at every duty status change. So, what you would do is when you do your pretrip, update your log for the new day showing when you did your pre-trip which city and state, then go to line 3. You don't have to show any drive time yet, just put the vertical mark to show you started driving. Then, when you stop, for whatever reason, you update your log again. Say you stop for lunch for an hour. So you'd go line 3 up until the time you stopped, then go to line 1. After lunch, you'd come back out, show your 1 hour on line 1, and mark up to line 3. Easy as that. Of course, there are ways to be a little more creative, but I'd rather not get into that if you are asking for basics.:biggrin_255:
    mjnkjn Thanks this.
  4. dancnoone
    dancnoone "Village Idiot"
    9,922
    3,713
    May 6, 2007
    You'll need to keep track of total milage, for end of the day reports on the log. "Miles Driven"
    Easy to do, just write your start milage down, then figure it up when you stop for the day.
    Some companies require that you write milage down at each state line. But not all.
    mjnkjn Thanks this.
  5. CURTWAYNE
    CURTWAYNE Medium Load Member
    465
    68
    Jun 4, 2008
    LITTLE ROCK, AR
    You do not have to mark you log book when you cross any state lines, or borders. Most companies have you write that information down so they can track how many miles you have driven in each state, so they can pay that tax. One company I drove for had a trip envelope with spaces available for that information on the back. The other company had us write it down on a route sheet. But, not in the log book.
    But, as danc694u stated, you have to keep up with the miles driven while on duty for the day, there should be a line for that just above the grid.
    I was taught it was always easier to keep your log book up to date, when you mark it at the time of the change. When you stop, mark it down. When you start out, mark it down just before you release the brake, and put it in gear.
    mjnkjn Thanks this.
  6. Raezzor
    1,412
    1,186
    Aug 1, 2009
    Columbus, OH
    Ya, I shot myself in the butt a few times for not marking fueling stops right when I did them and later found out the clock in my truck was well off due to the truck having been worked on. Ah well, I had so few log violations with safety they didn't say a thing about the 2 I got in one day from that little mess.
    mjnkjn Thanks this.
  7. mjnkjn
    15
    rockford,il
    Great advice Thanks!!!!! as I stated this is new for me my first yr was on computer logs (just sign in and out)
  8. kwray
    kwray Medium Load Member
    550
    280
    Jun 14, 2009
    Pennsylvania
    Companies that use GPS usually don't require that you track mileage in each state because the computer tracks that for fuel tax purposes.
