On Friday I drove for the first time this month. It fell under the 100 mile exemption so I only did company paperwork. Starting Monday I will not be under the 100 mile so I have to log. What do I put in my log so I have the 6 days worth? Do I have to create a separate page for last Monday through Thursday, I was assuming I do? What do I put down for Friday?
thanks
Log help with 100 mile and non 100 mile
Discussion in 'Questions From New Drivers' started by Leea, Aug 8, 2011.
You have to summarize the last 7 days prior to the current day.
Assuming you worked one day prior and whatever you did before that was non-HOS, assuming days are ordered as follows:
Day 1-6 off duty
Day 7 local driving work
Day 8 beyond 100 air-mile driving work (let's call that OTR driving)
Log page 1 Off-duty from midnight to midnight
in the summary section write off-duty Aug x - Aug y, 2011(with "x" and "y" being actual dates)
Log page 2 off-duty from midnight to when you started working (not when you started driving), then drop down to "on-duty, not driving" from start of work until end of work (which includes all of your driving). Don't detail your changes of duty status just makes sure you show on-duty, not driving for all of your time at work that day (which includes your driving time. In the summary section "local driving/work city, state"
Log Page 3 log it like you drive it. Do it just like an OTR driver.
BTW, are you sure you were under the 100 air-mile rule? That's not something the driver usually can just decide because he stays close to home. But that's another topic. -
Yeah, assuming you're a "local" driver, day 1-6, off duty, day 7, local, then Monday, log it as you do it. However, if you're an OTR driver, day 7 will be a "log-it-as-you-do-it" day, even if it's under a hundred miles.
Thanks, the round trip was 60 miles so it was local even though I did it a few times.
You should know it's not highway miles that makes up the 100 mile rule it's as the crow flies.
