logbook pretrip question.
Discussion in 'Questions From New Drivers' started by zoekatya, Apr 24, 2014.
  1. zoekatya
    zoekatya Medium Load Member
    397
    99
    Mar 15, 2013
    I run electric logs and when I first started I think I remember hearing from the people at the company that it doesn't matter if it's a pre trip or post trip one just needs to be in there somewhere. Is this true legally speaking?
  3. gpsman
    gpsman Road Train Member
    1,581
    1,211
    Dec 10, 2013
    45212/59759
    [h=3]§396.11: Driver vehicle inspection report(s).[/h] (a) Equipment provided by motor carrier. (1) Report required. Every motor carrier shall require its drivers to report, and every driver shall prepare a report in writing at the completion of each day's work on each vehicle operated, except for intermodal equipment tendered by an intermodal equipment provider. The report shall cover at least the following parts and accessories:
    http://www.fmcsa.dot.gov/regulations/title49/section/396.11
    So... drive it 600 miles, discover any deficiencies later.
  4. realsupatrucka
    realsupatrucka Road Train Member
    2,072
    513
    Sep 25, 2013
    houston tx
    You have to log a pre trip at the beginning of each day and do a post trip at the end of each day
  5. JohnBoy
    JohnBoy Road Train Member
    10,087
    27,597
    Apr 24, 2009
    Lake Worth, FL.
    Would the correct verbiage be "the beginning of each shift, and the end of each shift"?
  6. realsupatrucka
    2,072
    513
    Sep 25, 2013
    houston tx
    Yup...just what he said
  7. Macneil
    Macneil Heavy Load Member
    711
    426
    Dec 15, 2010
    Sudbury, ON., Canada
    I always do a pre and post trip...beginning of the day or shift the pre trip is usually 20-30 min. Post trip is usually 10-15. Find something on your post you can get it looked after before you start your next day or shift..
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    There is NO time requirement to log a PTI. Companies set their own policies, & DOT officers have their own interpretations, but just log what you do.
    The law says you must inspect equipment before driving it AND/OR be satisfied that it is in safe working condition. Technically that means no pti is required as long as you are satisfied with the condition. Practically, you should be at least checking lights, tires, & fluids. If that takes 3 minutes, log 3 minutes. If it takes 15, log 15.
    Tbe regulation further states that you must complete a report at the end of the day and note any deficiencies you discovered within a specific list of items. Technically it does not require you to perform an inspection, but from a practical standpoint you should. How long? As long as it takes to do the job.
  9. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    yep, double double yellow. written report at the end of each day.
    i flag a 5 pre and log a `15 post.
  10. Allow Me.
    10,724
    12,417
    May 28, 2009
    Rancho Mirage, Ca.
    You want to check your equipment BEFORE you drive it, right ? When you check it at the end of the day and go to bed, it will be the same condition the next morning, except for a possible flat tire that was up the night before and slowly leaked the air overnight. Most companies want a pre/post trip. You are allowed to post trip and fuel the same time. (to save hours). Always check your equipment whenever you stop, at least a walk-around.
  11. Dr_Fandango44
    Dr_Fandango44 Road Train Member
    1,053
    746
    Aug 27, 2012
    Austin, TX
    If you're on elogs, for example if you have QComm, there should be a drop down menu for change of status, and your company may want you to specify its a pre or a post trip, even though it's pretty obvious. Our company requires it, so it's a matter of what the safety dept wants.
