Logbook Question
Discussion in 'Questions From New Drivers' started by miker61002, Oct 2, 2010.
  1. miker61002
    miker61002 Bobtail Member
    12
    6
    Oct 2, 2010
    Titusville, FL
    If I drop my trailer and Bobtail for personal use (w/ company permission), to a dental appointment or to go sight-seeing, etc, for instance, is that considered "Off duty" or Driving (and applied to my HOS)?
  3. kenworthw900
    kenworthw900 Light Load Member
    285
    63
    Aug 17, 2010
    Washington
    When i was in school we had a DOT officer come in and talk to us and she said if you are using it for personal use and it's ok by your company then technically its off duty but again it would be your company's call
  4. Working Class Patriot
    Working Class Patriot Road Train Member
    12,683
    23,164
    Jan 17, 2008
    Wherever and Whenever...
    Log it on Line 1....Flag it: "Off Duty/ Driving...."
  5. moblue
    moblue Light Load Member
    130
    48
    Aug 8, 2010
    I had the same question. I unloaded in my home state approximately 60 miles from the house but needed to take the rig to my mechanic. I figured I was off duty. Someone was telling me no. I need to know.
    The truck is mine. Not a company driver.
  6. ChromeDome
    ChromeDome Road Train Member
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    The issue is that you are not supposed to log back on duty in a location other than the one you logged off duty on.
    So if you leave your delivery site, drive to the shop, then drive home, you may log this off duty. But you cannot log on duty till you are back in the place you went off duty.
    Also the question of going to the shop will come in. Technically if your truck is in the shop you are on duty bringing it to the shop. Since this is work related.
    Who the truck belongs to does not really matter.
    moblue Thanks this.
  7. wildbill123
    wildbill123 Heavy Load Member
    713
    322
    Jan 31, 2009
    SE,MI
    I asked dieselbear this question a few months back. He answered at length to the different situations. Try a search you might be able to come across his answer.
    From what I remember if you are not laden ( under load ) and you are off duty you do not have to log it. But it would be best to ask dieselbear or do a search.
    moblue Thanks this.
  8. cagey53
    cagey53 Light Load Member
    53
    23
    Sep 5, 2010
    Huntsville AL
    This makes sense, but what about this scenerio. Say an RV transporter doing driveaways leaves from the factory in Kansas, drives the RV to Seattle and delivers it to the dealer. This particular transporter does not use a tow car but is taking Amtrak back to Kansas. Didn't he go off duty in Seattle and will be off duty until he gets back to the factory?
  9. ChromeDome
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    In that situation he would need to explain it to the officer.
    But if he does not use a Tow car does he even have to use a log book?
    Since they would not have a DOT number assigned to a Mobil RV that moves under it's own power.
    The Tow car/ truck is the commercial vehicle, not the RV.
    So in that situation I cannot see him needing to bring a log book when transporting that RV. But when he gets back into his transporter or another CMV, then he will have to log his working time. In this case I would log it as on duty not driving time though. Since he was not in a CMV.
  10. cagey53
    53
    23
    Sep 5, 2010
    Huntsville AL
    I was looking into RV transport a few years ago before the RV industry went south, and the companies I talked with said that even driveaway transporters needed a logbook, though they did not necessarily need a CDL. At the time I didn't get into details, I just thought it was curious. Thanks!
  11. ChromeDome
    3,706
    2,086
    Jun 10, 2007
    Lakeland, FL
    I have never done RV transport so I could be wrong. I cannot see why you would need a log on a non-commercial RV.
    The only reason I can see is for tax purposes. Since if you are on a log and subject to federal HOS, then you get a larger per-diem deduction than the standard for other workers.
    Now if you must put your company info and DOT number on the RV for transport then I can see it being a temporary CMV, in which case you would have to do it.
    In that case I would make a note in the notes section on the bottom of the log saying that I took alternate transport home.
