Long Distance with Interlock On?
Discussion in 'Questions From New Drivers' started by deafaviator, Dec 21, 2017.
  1. deafaviator
    deafaviator Light Load Member
    81
    113
    Sep 25, 2017
    About to head up I-70 in snow for the first time in a rig. Plenty of advice on here that I’ve been reading regarding driving mountains in snow, but what I’m not clear on is:
    Is it okay to drive the whole thing with the Interlock on?
  3. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    If is slick you can but if you are hitting dry spots like the tunnel switch it off, just let off of the power when switching.
    Lepton1 and Tb0n3 Thank this.
  4. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,763
    Mar 9, 2014
    In a van down by the River.
    I wouldnt. Never used it while driving. Just to get going.
    Grubby and austinmike Thank this.
  5. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,542
    May 22, 2017
    I've drove many miles on dry parent never heard funny noises. Even going down hill at 96mph once. Just make sure you do not dis engage above 55mph. That is the key.
    Lepton1 and diesel drinker Thank this.
  6. Oxbow
    Oxbow Road Train Member
    12,787
    132,312
    Nov 24, 2015
    Why not disengage above 55?
  7. Oxbow
    12,787
    132,312
    Nov 24, 2015
    Personally, I don't use it going downhill, because I would rather have only one out of four lock up due to jaking than two out of four. But that's just me.
    tinytim, magoo68, Grubby and 5 others Thank this.
  8. Oldironfan
    5,777
    5,542
    May 22, 2017
    Clunk. Clunk.
    Kinda like a pickup when you engage or unlock at to high of speed.
    Lepton1 Thanks this.
  9. Oldironfan
    5,777
    5,542
    May 22, 2017
    I forgot they were engaged.
  10. swaan
    swaan Road Train Member
    2,942
    4,374
    Jul 12, 2009
    BC canada
    Your fine... if road is slippery or compact drive with it on all winter long.
    You can also engage or disengage anytime you like as long as your not spinning out . I usually just lift off throttle and flick on/off.
    Now diff locks are a different story...
    MACK E-6, Lepton1, Hammer166 and 4 others Thank this.
  11. Truckermatt74
    Truckermatt74 Bobtail Member
    34
    25
    Mar 21, 2013
    Montana
    Gear guys always say "use it if you need it only". Been hauling logs and chips in and out of woods 18 years now, very rarely do I use it on the highway unless climbing a steep hill, or taking off from being stopped on covered road with snow or ice. Last year given the bad weather I used it a couple times going up Evaro, Lookout Pass and Homestake in MT. In the woods on dirt roads or in a dirt log yard its always on.
    Farmerbob1, Lepton1 and Oxbow Thank this.
