long extended crank on start up on c15 acert
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SimD, Sep 3, 2013.
  1. SimD
    SimD Light Load Member
    148
    30
    Dec 23, 2012
    dallas, tx
    Got two truck both with c15 acert. Both trucks are same exact. One starts up right away. And the other has a long extended crank. It has brand new batteries, cleaned all cables for corrosion even on the starter. But it still has a long extended crank. Feels like it doesn't get fuel right away. Anyone know what can be causing this?
  3. TA63
    TA63 Bobtail Member
    48
    Oct 28, 2010
    Truck is losing it's prime somehow. My 05 had a bad fuel tank shutoff valve that drew air into the fuel system. Amazing how much better the truck started and ran after fixing it.
  4. dude6710
    dude6710 Road Train Member
    2,162
    622
    Mar 26, 2010
    MN
    Miles? Starter been replaced?
  5. little cat 500
    2,048
    1,094
    Jan 17, 2010
    Abbottstown PA
    proly loseing prime on the head bad regulator or lift pump
  6. Down under trucker
    Down under trucker Light Load Member
    145
    62
    Jun 22, 2012
    Brisbane, Australia
    Leave the key in the on position for about 30 seconds before you start, if it starts right away, you are loosing prime somewhere
  7. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    try a new fuel check valve in the secondary filter housing, part #238-0296, sounds like a classic case of it leaking.
    JohnP3 Thanks this.
  8. cetanediesel
    cetanediesel Medium Load Member
    470
    186
    Mar 26, 2013
    Albany, NY
    Is there an electric pump on a C-15?
  9. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    Nope. Key on will not make difference on a cat.
  10. Down under trucker
    145
    62
    Jun 22, 2012
    Brisbane, Australia
    Sorry didn't realize c15's don't have an electric lift pump
  11. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    I agree with the check valve in the filter housing. It could also be the hand pump, but you generlaly see at least some dampness on or aournd them when they start to leak.
