I am looking for a new cd player and radio combo the one I have in the truck now finally die (cd player). So am looking for a new one. Anybody have any good suggestions Panasonic was okay but looking for a different brand or one have better features and just a little better sound or some better wattage in your cottage type system.
Look for an new CD in dash player
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by v6killer, May 19, 2011.
Page 1 of 3
Pioneer, Sony, I've got a Panasonic in my truck that's alright. Just head on over to Best Buy and fiddle with the display units till you find one you like.
One thing I just did was take out the stock rear speakers in the ceiling, bypassed them by plugging in more wire that now runs to my 6x9's in boxes sitting on the shelves in the sleeper, and put the stock ones back in. Sounds much better, took about 10 minutes, and nobody will notice unless they take a close look.
Thank you for the replies,
If I install and new radio do I need a new wiring harness, let's say for the new Sony or Alpine.
On an Volvo 2007 780 -
Never done a volvo. Kenworth just ties the wires together with electrical tape and I use wire nuts to connect them to the new stereo. I don't know if they make adapters for factory plugs, if it even has one. Best take it out and look to see what you're dealing with. On the KW it's much easier to remove the glove box and pull the wires out through there instead of trying to fit your hands into the hole in the dash.
I doubt that. Never seen a stock system that uses that many speakers with an amp built into the head unit. Especially not with a sub. That means there's a factory amp hidden somewhere. That also means that the factory head unit puts out less power, not more. An aftermarket stereo might in fact burn the amp out unless you use the preamp outputs instead of the regular ones. I'd check over every inch of that truck to make sure there wasn't an amp hidden somewhere in the circuit before putting a new stereo in.
If there isn't one, and you're absolutely sure of that, then you might need to wire in a small amp or a powered EQ to make up the difference. Basic head units aren't designed to drive that many speakers by themselves. -
Am not sure about the pre amp, I know the radio is an 50w system in the Volvo.
Page 1 of 3
