lookin for some tips running an end dump for a new guy
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by turbo torquin cowboy, May 19, 2014.
  1. turbo torquin cowboy
    turbo torquin cowboy Bobtail Member
    33
    34
    May 19, 2014
    Colorado Springs, Colorado
    Ok. So ive been driving for about 1.5 years I started out on a 38 foot end dump and from there learned all of the other dirt tuckin equipment except a side dump im 24 I like to believe im good at what I do but im always looking to learn new things, hence the reason im doing this right now I drive a late 90s 379 pete with an old ### beat up load king end dump im hauling 4 to 5 foot boulders for a couple of weeks and well. Any tips!!!!
  3. korky
    korky Light Load Member
    97
    56
    Aug 14, 2013
    AZ
    I used to run similar sizes boulders for Parsons Walls. I always held the trailer brakes with the steering wheel mounted lever, the actual name escapes me right now, and the truck brakes released. Raise the box and once the boulders start to roll out I stopped lifting and waited for them to stop all the while holding my foot on the brake. As the boulders spill out and hit the ground they will build up and actually keep you from tipping. I would then raise the box release the trailer brakes and use the foot brake from there. It got a little hairy a few times but never laid it over. Good luck!
    turbo torquin cowboy Thanks this.
  4. turbo torquin cowboy
    33
    34
    May 19, 2014
    Interesting I might try that method what I normally do is use the jonny brake and relese it as soon as the boulders come loose and it pushes me forward and so on. I also haul anything to do with aggregate but these boulders are for erosion control after these fires in Colorado springs. I'll only be doing this project for about another week. Any tips for hauling sand or other types of loads in an end dump. Tricks of the trade? Criticism? Lol. Im always eager to learn more from you seasoned vets
  5. korky
    97
    56
    Aug 14, 2013
    AZ
    Always hold the trailer brake when dumping. NEVER let the trailer creep forward. Regardless if you have a frameless, quarter or full frame dump be cause if there is a rut you didn't see or you made one by hitting the brakes too hard things can get interesting. Lots of pucker
