Looking at engine specs and transmission for fuel efficiency
Discussion in 'Ask An Owner Operator' started by Cdubb, Dec 28, 2021.
  1. MadScientist
    MadScientist Light Load Member
    99
    144
    Dec 14, 2019
    If you're in the same gear and doing 60 mph at 1700 rpm, at 1800 rpm you're only doing 63.5 mph, not 65.
    Cdubb Thanks this.
  3. Cdemars316
    Cdemars316 Heavy Load Member
    823
    4,992
    Nov 10, 2018
    Had a 3176 hooked to a 9 speed in my first truck, loved that little motor, always ran good , not a great highway truck but was respectable running around heavy with belly dump loads
    Cdubb Thanks this.
  4. supergreatguy
    supergreatguy Road Train Member
    1,030
    2,895
    Nov 26, 2020
    Series 60 14.0 deleted (proper) 600hp right under 2k torque ride steady at 70 at 78k lbs gross getting about 7.1 mpg. Don’t know my gear ratio but it’s G enough
    Cdubb Thanks this.
  5. abyliks
    abyliks Road Train Member
    3,997
    9,401
    May 2, 2010
    ludlow MA
    Double check the trans and if it’s still an Rto not an rt you could try swapping to 11r24.5s which makes 3.90 a great a highway gear
