Looking for a 4 valve E6 Mack engine
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by mile marker 27, Oct 7, 2025.
  1. mile marker 27
    mile marker 27 Road Train Member
    1,386
    1,716
    Dec 4, 2019
    Ruined the crank in an ‘86 Superliner, due to #5 cylinder rod bearing. Looking for another E6 300 - 350hp engine.
  3. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Both my bro in laws are retired Mack engine builders….and two of my buddies w/super liners still working are regulars on here
    They tell me it’s the best place to get Mack info….lots and lots of the eastern Pa Dutch mafia w/years of info
    Good luck
    BigMackTrucks.com
  4. mile marker 27
    1,386
    1,716
    Dec 4, 2019
    I don’t know squat about a Mack engine, but they’re more similar to a Cat setup, than a Cummins. This is my in laws truck and over the past few years they’ve swapped injection pumps on it a couple times and they’re not diesel mechanics(not that I consider myself one) but I do realize they time off the pump. The pan was already dropped, when I got there this afternoon and there’s literally no top rod bearing left of #5. There’s only about half the bottom bearing. Everything else up through the hole looked fine, including liner and piston cooler. #5 journal is ####. Didn’t notice anything as bad from any other cylinders. Thrust washers looked fine too, with very minimal end play.
  5. BoxCarKidd
    BoxCarKidd Road Train Member
    4,536
    6,605
    Aug 26, 2014
    Would they like a Super Liner with a factory cat? I thank it is in frame time but it is complete and runs.
    North Pole Nightmare Thanks this.
  6. mile marker 27
    1,386
    1,716
    Dec 4, 2019
    I’d drive it, if it had the Cat in it. A or B model Cat? A2A or JWAC?
  7. PSM379
    PSM379 Heavy Load Member
    939
    3,857
    Apr 19, 2019
    if he doesn’t take it this definitely peaks my interest.
  8. BoxCarKidd
    4,536
    6,605
    Aug 26, 2014
    B Model with a bad 13 speed. Air liner cutoff. Good tires robbed off of it. Not mine I just know when it is at.
