the reasoning is this.
i took my truck into kenworth in salt lake for an oil change,engine liught has been on and shutting down the truck ever since. one of the codes is abs and speed sensors, to which there is a cut wire hanging on the rear end. had no check engine light or engine problems before oil change.
2 weeks later at another shop,. fixing the same engine light shutdown problem. the truck was ddropped off with 3/4 tanks and only had 1/4 at pickup.
anyone know of some type of surviellance camera i can use for when the truck is in the shop. or even parked for extended periods.
looking for a surviellance cam for the truck
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by snowwy, May 20, 2012.
Here is the number of a guy I bought mine from 214-766-6008
Wait you want a camera to spy on the guys doing repairs? Sounds like that is what you want.
Just buy a GoPro. They'll record up to 8hrs if set right and are pretty cheap and useful.
8 hours isn't gonna cut the mustard when the truck is in the shop 4 days.
and when you take a truck in with no problems. but leave with an engine light and a cut wire. and $4000 pumped into a problemm that still isn't fixed. or your tanks are almost empty when they were almost full. at one shop that actually made SOME type of progress in cutting down the problem.
now i understand things happen and that it may just be coincidence. but i didn't have an engine light problem flipping speed sensor codes and everything else. nor did i have cut wires when it was dropped off. just becuase i didn't want to buy part after part that didn't need to be.
i think it's time for some surveillance. -
If you call that guy I gave you the number to he will get you rolling. The use almost no juice so you can leave it running all the time. Mine shoots in cab and front of the truck, but he will cut ya a deal for more I bet. Sorry about what happened I hope you get it resolved!
i'm thinking probably one on eachy mirror bracket with wide angle. to keep an eye on each side of the truck from fuel tank to engine.
what would be sweet, would be to have them record to a memory card. rather then plugged into a laptop. all you had to do was pull the card out and insert into laptop for viewing. -
I like the wildlife surveillance camera's at Walmart.
http://www.walmart.com/browse/Cameras-Camcorders/Digital-Cameras/Rugged-Outdoors-Cameras/_/N-99oh?browsein=true&_refineresult=true&_refineresult=true&_refineresult=true&ic=32_0&path=0%3A3944&ref=+432449&povid=cat133277-env203316-moduleA032212-lLinkLHNRuggedCameras -
An SD-card DVR with 2 cams with a 32 GB memory card in it will record about 29 hours before it starts to over-write the earliest video if set on highest quality. If you lower the quality to "normal" and set the frame rates from 30 fps to 15 fps then you would get more like 4 days recorded before it began to over-write. But again, you give up quality or frame-rates to extend time. If this is enough recorded time then that will be the cheapest at about $600. (max of 4 cams capable)
If you want more video stored than 29 hours and want GPS position (video shown with a Google Map next to it when you play back on the computer) then you need a system with a hard drive instead of just the SD method. Like, a 250 Gb hard drive would store about 9 days of video on highest quality before it began to overwrite oldest videos then you are looking at more like $900. On "normal" quality that hard drive would go 16 days continuous before over-writing.
