Looking for an RGN that weighs around 15,000 lbs.
Discussion in 'Heavy Haul Trucking Forum' started by tommyt, Oct 14, 2018.
  1. tommyt
    tommyt Bobtail Member
    5
    I am looking for a 35 Ton RGN. Can anyone tell me if there is one made that weighs around 15000 pound. The one I have is 20000.
  3. Rontonio
    Rontonio Road Train Member
    6,297
    45,872
    Aug 9, 2009
    Sure go order a Murray 16 tire mechanical
    It will be like 14000 but will probably cost $120k... and have a 21’ well
    wore out, Rugerfan, cke and 1 other person Thank this.
  4. archangelic peon
    archangelic peon Medium Load Member
    504
    376
    Dec 15, 2011
    What is the expected service life of something like that?
  5. Rontonio
    6,297
    45,872
    Aug 9, 2009
    A 20 yr old Murray still sells for $70-80k
    Just saw a 1999 for $80k
    truckdad, cke and Oxbow Thank this.
  6. johndeere4020
    8,522
    119,292
    Jan 1, 2010
    Where are you and what do you have now.
    cke, Oxbow and SAR Thank this.
  7. johndeere4020
    8,522
    119,292
    Jan 1, 2010
    That’s an odd answer. Is a 16 tire a 35 ton trailer?
    m16ty, cke, Oxbow and 1 other person Thank this.
  8. Rontonio
    6,297
    45,872
    Aug 9, 2009
    I know it is over kill and a ton trailer is mostly just a 5 axle set up anyway - so being a “2 axle” doesn’t hurt. The OP asked if there are 15000 lbs 35 Ton trailers .... and there are. I didn’t say that it would the perfect trailer - as I pointed out it is a short well/short neck trailer that is expensive. The question is what is he trying today accomplish that a 15000 lb trailer allows that a 20000 lb doesn’t.
    cke, Rugerfan and Oxbow Thank this.
  9. Rontonio
    6,297
    45,872
    Aug 9, 2009
    And I not sure if they will anymore but you used to be able to order it as an 8 tire version. Cozad will make you one also.
  10. johndeere4020
    8,522
    119,292
    Jan 1, 2010
    A 16 tire Murray only weighs 15,000? I would guess he’s trying to haul 5000 more payload while staying under some weight be it 80,000 or some permit number.
  11. Rontonio
    6,297
    45,872
    Aug 9, 2009
    Minimum 40 Ton - cozad makes a 44 ton
    It will more than hold as a 35 ton
    canadianrebel, cke and Oxbow Thank this.
