Looking for more power
Discussion in 'CB Radio Forum' started by hetdiesel, Apr 22, 2012.
  1. hetdiesel
    hetdiesel Bobtail Member
    27
    Nov 25, 2009
    PA
    I have a general lee that has been peeked and tuned from a local cb shop and looking for some more power im looking to spend maybe 200-300 and this. ive been looking at amps and really do not know nor want to spend the time to learn about all the technical stuff. I have a rk56 mic and a wilison 5000 antenna already so what next guys?
  3. cadillacdude1975
    cadillacdude1975 Road Train Member
    1,081
    394
    Mar 20, 2010
    Chattanooga, TN
  4. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    This is the only amp I use 150 watts on 2 meters more than enought ......
      File size:
      147.3 KB
      161
  5. Mad Dog 20/20
    Mad Dog 20/20 Heavy Load Member
    768
    193
    Jan 31, 2010
    Skid Row
    I don't think the Mirage would work very well with the General Lee!! I use an old brown face Mirage ( when they were manufactured in California ) for 2M weak signal work.
  6. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    No it would not and your amp preamp would kick mine into the next state ....
    The new ones are junk ....:biggrin_25513:
    Still at 150 watts and run the tampabay SSB net ( 144.210 ) no one has a problem hearing me ....
  7. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    With the General Lee, I would go with the Texas Star 500V...Gen.Lee is going to be a little too much drive for the TS 350...
    As for not wanting to know all the "Technical Stuff"...Bit of advice, If your going to run "Power" you best know what your doing, or your asking for allot of headaches...
    Hooking up a Amp is not any harder than hooking up the CB Radio...But getting everything properly adjusted and dialed in, is another story
  8. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
  9. hetdiesel
    27
    Nov 25, 2009
    PA
    so having someone install would be best plus my chan light seems to be burning out i only have half a 1 on the dim setting and sometime the volume will not get louder.
  10. DX-trinity
    DX-trinity Light Load Member
    82
    17
    Jan 29, 2012
    Ashton, NE
    Call X force amps off there web site.They will help you even if you don't buy from them.You are going to need a 4 pill for the higher dead key the general lee has.Make sure your SWRs are in check,the extra power will add to it some.It's also a good idea to run an in line meter so you can keep an eye on stuff.With power come responsibility and money.
  11. WA4GCH
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    You are going to need a 4 pill :biggrin_2556: is that kinda like transistors ....
    My next amp will have 4 tubes ...
    The silver radio is 5 watts .... all I need to work around the south east us .....
