Looking for some advice regarding my Freightliner with low oil pressure
Discussion in 'Experienced Truckers' Advice' started by Southsidetrucker, Jan 7, 2025.
  1. Southsidetrucker
    Southsidetrucker Bobtail Member
    16
    15
    Jul 6, 2022
  3. Southsidetrucker
    16
    15
    Jul 6, 2022
    Yeah my ELD reads all active fault codes and it will tell you when the code was first and last observed so I know it’s a bunch of ########.
    I denied the bearing inspection and after a brief talk with the manager they went ahead with the stand pipe replacement. I gave them permission to drop the oil pan and no metal was found in the pan or oil filter so that’s a good sign . Also told them to replace the oil suction manifold so hopefully all goes well . They should be done tomorrow.
    Rideandrepair Thanks this.
  4. MAMservices
    MAMservices Medium Load Member
    483
    3,357
    Aug 9, 2021
    If I remember correctly, you cannot clear a “fatal historic event”, like low oil pressure, over temp over speed or the like. This means that the 4000 seconds are an accumulation, and not necessarily happened at one time.
    AModelCat Thanks this.
  5. AModelCat
    158,343
    Makes sense. It probably adds a second or two every time you start the engine.
  6. MAMservices
    483
    3,357
    Aug 9, 2021
    Again if I’m not mistaken, DDEC III and above, will wait to record an “event” for 3 seconds. This is why when it shuts down, you can turn key switch off, wait, then restart it and it will take a few seconds for it to “recognize”, it has no oil pressure even if there is no oil in the engine. DDEC doesn’t record anything until it sees the engine is running. If it did, it would log low oil pressure if you left the KOEO. If you have a sensor bad, unplugged or what, I think it sees that and will throw a code after, 2 engine revolutions, 3 maybe?
