Looking for the best washer fluid
Discussion in 'Questions From New Drivers' started by Guitar Hero, Aug 13, 2019.
  1. Guitar Hero
    Guitar Hero Bobtail Member
    4
    Ive tried the blue and the green jug from peak. Neither does the job. Anyone have any success with using a different product. Or making your own homemade solution with vinager/water ? Thanks!
  3. lovesthedrive
    lovesthedrive R.I.P.
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
    Next time you fill it? Put a teaspoon (about a squirt) of dishwashing soap in. It will help cut down the surface tension and help remove the bug splatter. Personally I use dawn, yet any liquid dish soap will work.
    Guitar Hero Thanks this.
  4. buddyd157
    buddyd157 Road Train Member
    13,566
    34,855
    May 25, 2017
    under a shade tree
    fill tank with water, add dish soap
    fill tank with water, add any laundry detergent (liquid of course)
    buy washer fluid....buy soft scrub pads, climb on top of tire(s), scrub glass.
    no matter what you use, or buy, unless you can remove the dead bugs in seconds, they are gonna dry up.
    company truck?
    buy ordinary washer fluid.
  5. FlaSwampRat
    FlaSwampRat Road Train Member
    4,900
    17,796
    Jun 1, 2019
    Valrico FL
    I rainx the ever loving crap out of my windows, helps with keeping crap from sticking to them.
  6. stacks
    stacks Road Train Member
    1,501
    814
    Oct 27, 2011
    Emerald Isle
    Buy the washer fluid in Walmart cheap and cheerful
  7. D.Tibbitt
    149,016
    Dawn dish soap is good for everything. I have even washed my entire truck with it. Im sure it could remove all the grease from ur 5th wheel if u wanted to.
  8. buddyd157
    13,566
    34,855
    May 25, 2017
    under a shade tree
    when i was able to sneak into the customers water spigot, using a splined socket, (as they took away the spigot handle), i also used dawn soap..it IS a very good degreaser.
    then this one time, i got no water out of the spigot...
    the customer shut off the water from inside the building......!!
    believe it or not, most times, i washed my truck when i got in saturday mornings at like 4 AM, and yes, washed it if it rained, so as not to show water on the ground....musta been some "suds" someone saw, and i did not use a whole lotta soap..!!
    D.Tibbitt and lovesthedrive Thank this.
  9. lovesthedrive
    15,953
    54,484
    Nov 11, 2008
    Sorrento Maine
  10. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Orange RainX , seems to work better then the green RainX . Even thou the green is for bugs ?
    sevenmph and lovesthedrive Thank this.
  11. jamespmack
    215,834
    Dawn will sure strip the wax from your paint however.
    Buy the cheap stuff and put some simple green in it. It works on the calcium chloride up north very well.
    Plus fill a weed sprayer with simple green 50/50 with water. Before it rains heavy spray down truck and trailer. Not a 100.00 truck wash, but it sure helps.
