Looking to buy a Kenworth T600
Discussion in 'Ask An Owner Operator' started by a-backwards, Sep 21, 2012.
  1. a-backwards
    a-backwards Bobtail Member
    7
    Mooresville, NC
    Looking for a lil bit of help... I finally found my dream truck a 2000 KW W900L, w/ studio sleeper, 550 Cat 6NZ, 13spd, had the motor overhauled..... them I wrapped it around a tree 3 weeks ago. I know sucks to be me, right. Well I'm looking to replace that truck, but with these fuel prices, my first concern is fuel ecomomy. I was getting 5.5 to 6 mpg with my W9, but I need to do better than that. I had a 96' KW T600, w/ N14 425, 13spd, and that truck got 7mpg plus without a problem. So anyway, I've been lookin at other trucks Freightliner Century, Volvo 770, and KW T2000, all of which have issues I don't like. I would love to have another T6, pre egr (maintenance being my second concern) I just can't seem to find one spec'd out like my other one. I love KW trucks, but after all these years that sleeper in the T2000 still sucks to me. And the only way I'd buy another Century, is if it has the O/O specs (I also had a Century).... So if any of you guys know of a nice pre egr T600 let me know, cause I'm looking for one (again). Also, feel free to leave any concern or input on any of the trucks I mentioned earlier. Thanks again.
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    I got my century off of truckpaper.com
    You can set your search requirements. Mine even came with my name on it.
    I would even go so far as to getting an APU. It saves the idling. When I do idle, I have egr issues.
    I've got a century w/ a 14 S 60 in it 13spd. I didn't like it not having the full gauges, but can do do just fine without them. I like the space and room a lot more in my century than a T600 or the W900's I was looking at.
    In the end, it came down to finding what I wanted and what the finance companies would work with me on. Some of it based off age and mileage.
    I would go for the older N14 engines or else get a 12.7 or 14L Series 60 long before I get a newer Cummins or even a Cat engine. As strong as a Cat is, unless I was looking to go heavy haul, I wouldn't' consider it due to history of poor mileage out of them. That's $15,000 or more I could use annually than the privilege to have a Cat.
  4. a-backwards
    7
    Mooresville, NC
    Yeah, I had a Century, prior to getting my 1st T600, it was an O/O spec'd w/ 18 full gauges and 13spd, I need gauges, I have to know what's going on at all times, I guess its a PACCAR thing in me, that Century I had was nice I can't complain
  5. a-backwards
    7
    Mooresville, NC
    Actually, I'm considering buying another Century, now.
  6. MNdriver
    7,985
    4,371
    Feb 24, 2012
    I am working on the "details",
    But as I understand the information NOW, I have a wiring harness for the full guage pack. I only have the "fleet" gages on the truck though.
    Armed with that, I am now looking into whether or not I can install a different dash pack into my truck. If I can, I will be putting the "O/O gages" like you are talking. And it should be "plug and play". The connections are there, they just didn't put the full gage pack in.
    The biggies that I am REALLY wanting right now are the pyro and the turbo boost gages.
    What I have learned is that as soon as you sense/find/determine you have even a slight exhaust leak, GET IT FIXED ASAP. It will lead to turbo/EGR failure. So what SHOULD have been $1000 or less to fix, will end up costing you $5,000 or better.
  7. Ukumfe
    Ukumfe Medium Load Member
    301
    515
    Oct 23, 2008
    I could be wrong, but I would bet that Freightliner ( as well as the rest ) uses the same wire harness in all of the trucks and only uses what the order calls for. I.E. "fleet" or "all the gauges". I can only imagine how many different harnesses would need to be stocked to conform to all the different options available. I would think it would be a huge nightmare to have so many different harnesses.
  8. MNdriver
    7,985
    4,371
    Feb 24, 2012
    exactly why I didn't get too concerned about not having the gages in the truck I actually wanted. It should be easy enough to put them in at a later time.
    I just have other issues to address right now before gages.
