Looking to buy ice cooler to keep drinks cold 6 days
Discussion in 'Questions From New Drivers' started by RockyTopTn4life, Jul 7, 2017.
  1. RockyTopTn4life
    RockyTopTn4life Light Load Member
    197
    33
    Nov 26, 2016
    is there any recommendations do any of the expensive style really work , thanks for any reviews of any that would hold ice or should 3 days be most to hold ice then refill once a week .. kinda like to have one with water drain hole also . Thanks in advance for advice ....
  3. dngrous_dime
    dngrous_dime Road Train Member
    3,150
    5,765
    Jan 28, 2014
    Lansing area, MI
    For the $250+ you would spend on a bells and whistles Yeti cooler, just go buy an Igloo 12V cooler for under $100, and not worry about draining.
  4. mindes
    mindes Medium Load Member
    626
    540
    Feb 17, 2015
    Crestview, Fl
    I have an igloo extreme that does alright. Ice will last in the summer about 2-3 days with the cooler sitting in between front seats. Have a hose attached to the drain with a valve on the end.
  5. RockyTopTn4life
    197
    33
    Nov 26, 2016
    Nice keep them coming probably will buy tomorrow is my day off ,,
  6. Cottonmouth85
    Cottonmouth85 Bad Influence
    2,637
    8,701
    May 3, 2012
    Floresville, Tx
    Unless your dead set on using ice I'd suggest an Engel. But I'm not sure what your application or budget is, either.
  7. RockyTopTn4life
    197
    33
    Nov 26, 2016
    Engels I hear is good but it hurts my battery life the company truck has a weak AC AP U and I run out of power 8 hours 9 if lucky anything more pulling and I may be down to 6-7 and No AC is bad can't sleep , but thanks
    Cottonmouth85 Thanks this.
  8. Ridgeline
    22,402
    116,509
    That makes no sense, how does a 3 amp draw on 12 volts effect the APU and the A/C?
    Lepton1, Cottonmouth85 and austinmike Thank this.
  9. noluck
    noluck Road Train Member
    1,616
    11,683
    Jun 10, 2011
    greenville,sc
    Battery powered apu
    bzinger and Cottonmouth85 Thank this.
  10. RockyTopTn4life
    197
    33
    Nov 26, 2016
    Yes battery powered APU they are awful
  11. RockyTopTn4life
    197
    33
    Nov 26, 2016
    Please advice on a cooler , I am not lying about having a short battery life while sleeping .. I would love a electric cooler no ice etc , but I can't have my full ten in AC as it is , I don't want anything else pulling at my amps , I assume it will cause I spoke to a few guys that works at my company and they said anything u use power with will pull from the batteries .. anyone still use the ice coolers with luck or have same problem I have with battery APU ?
