looking to change my axle ratio
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rank, May 30, 2014.
Thread Status:
Not open for further replies.
  1. rank
    rank Road Train Member
    9,918
    113,505
    Feb 11, 2010
    I recently bought a '86 Pete 359 with a 3406B. It has a 3.90:1 Rockwell SQ100 rears, 24.5 LP rubber and a 15 OD. 62 mph is 1750 rpm and I want to get those revs down. Thinking about maybe a 3.42 or something. Can anyone recommend a shop in NY, PA or ON? I can either go with new crown and pinion or swap the diffs.
  3. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I wouldn't go past 3.55 if I were you. Those old engines like to spin a little more than the modern ones. 1500 at 65 would be as low as Id go. My old t-6 ran the same rpm as yours and got 7 to 7.5 mpg doing it. It had an 8LL with 4.11's and short rubber. On those rears check the spindles for wear also before spending too much. A lot of old ones I've seen have worn spindles. If they're really bad you might be looking at new housings.
    rank Thanks this.
  4. tw1005tx
    tw1005tx Light Load Member
    60
    18
    Feb 24, 2011
    Most of the older eng's were governed 2100 with a low about 1700 below that was considered lugging, its probably a 70mph trk at 2100.
    rank Thanks this.
  5. rank
    9,918
    113,505
    Feb 11, 2010
    3:42 puts me at 1600 at 65 mph?
    At least on of these diffs are only a couple years old. I was hoping to get away with a ring and pinion swap. Domar has one 3.42 on the shelf quoted me $1300 to swap the ring and pinion the rear and $1500 for the front.
  6. Oscar the KW
    Oscar the KW Going Tarpless
    12,246
    28,116
    May 19, 2011
    I'm not an expert, but when I was looking at re-gearing my truck, my local shop said that you can run the same carrier and switch between 3.55 - 4.10's. I believe to run a 3.42 you would need a carrier from anything with 3.08 - 3.42's.
    wore out Thanks this.
  7. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    how good is the truck....I would sell the truck and buy one with the correct rears. Swaping them is gonna be a few grand anyway. WHat speed do you want to cruse at? Whats your proorety? High top speed? Mpg? Check out the eaton rear end calculator. http://www.eaton.com/ecm/groups/public/@pub/@eaton/@roadranger/documents/content/ct_062746.swf If mpg is your concern get a rear that would allow you to switch to 22.5 tires.
  8. rank
    9,918
    113,505
    Feb 11, 2010
    359's ain't growing on trees LOL. Speed is not a concern. I usually run 60-62 mph. I'm already spinning 1750 at 60 mph on 24.5 rubber I think I would red line with 22.5.
  9. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    For a shop, I've had really good luck with the guys at Heavy Duty Parts in Scranton. Heavy Duty is a chain that specializes in drivelines, but don't go to any of them, some really suck. I trust the guys in Scranton with our transmissions and rears, I've been using them for years with no issues and they know their stuff. In Scranton, Gene is a straight forward honest guy.
    RERM and rank Thank this.
  10. rank
    9,918
    113,505
    Feb 11, 2010
    Thanks Grape. Scranton might work.
  11. rank
    9,918
    113,505
    Feb 11, 2010
    Seriously? Good grief I'll need ear plugs.
  • Thread Status:
