Looking to upgrade from my cobra 29
Discussion in 'CB Radio Forum' started by padriver87, May 11, 2011.
  1. padriver87
    padriver87 Light Load Member
    60
    36
    Feb 20, 2011
    Sykesville PA
    Im looking to upgrade any suggestions would be apreciated i would like a radio that can realy get out there right now im pushing 80 watts with my 29 i have a wilson trucker 2000 antenna but would like a radio with a little more power:biggrin_25521:
  3. Turbo-T
    Turbo-T Road Train Member
    1,953
    708
    May 31, 2009
    First things first have you ensured you have a low SWR from your antenna? 1.5:1 is what you want, 2.0:1 is ok, anything higher than 2.1:1 reduces transmit efficiency.
    If this checks good, the next step would be an amp. Since you say your radio does 80 watts (presuming you must have an RFX75) then you'll want to ensure whatever amp you buy can handle the amount of power the radio is doing.
    If you want to stick with an all in one unit, a Connex 4300-300, if you can find one, would most certainly fit the bill.
    padriver87 Thanks this.
  4. padriver87
    60
    36
    Feb 20, 2011
    Sykesville PA
    i have been debating between the 4300 300 and the 4600 turbo i have my current radio pretty diled in im at about 1.2swr but still not getting out as well as id like.
  5. Turbo-T
    1,953
    708
    May 31, 2009
    How far are you wanting to try to get out?
    Most mobile CB's have a range of 5 miles, reliably. The trees, mountains, skip conditions, etc will also determine how far your signal travels.
  6. padriver87
    60
    36
    Feb 20, 2011
    Sykesville PA
    not so much get out as talk over all the riff raff haha
  7. Yup
    Yup Medium Load Member
    569
    129
    Apr 2, 2011
    Everywhere,USA(Texas)
    43/300 is a great radio,abit pricey for the performance
    but its been around a good while.
    Many havent been impressed with the 4600,then again some like them so ...?
  8. WA4GCH
    WA4GCH Road Train Member
    3,324
    577
    Aug 12, 2009
    Seminole Florida
    GASP :biggrin_2556: look at the size of the finals .....
    I run several VHF radios that run around 100 watts FM and they an't kidding when they say the heat sink gets HOT.....
    SO I installed a 12 v fan to blow air on it. What a diffrence in how hot they get ...
    very cheap insurance for extending the life of your radio .....
  9. Turbo-T
    1,953
    708
    May 31, 2009
    What's the "riff raff" you refer to? Are you trying to be the biggest dog at the truck stop? The one that can key up and lock down the channel?
    Yup Thanks this.
  10. padriver87
    60
    36
    Feb 20, 2011
    Sykesville PA
    Haha i guess you could say that but pretty much the only time i use it is when i need to talk and its important being the big dog is just a plus
  11. this_is_nascar
    this_is_nascar Light Load Member
    101
    25
    Jun 25, 2008
    Gloucester City, NJ
    Always attempt to get the best SWR you can, which is 1.1:1. Any higher results is a loss of efficiency. At 1.5:1 SWR means a 3% loss of efficiency. Is it noticeable, probably not, but you should strive for a 1.1:1 match.
