Loses all electrical power
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bigguns, Dec 2, 2015.
  1. bigguns
    bigguns Road Train Member
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    A fella I work with has a 1995 IH with a Detroit in it. For some some reason it loses all electrical power. He waits 5-7 minutes and the truck will start and run fine for another 35-40 minutes. Then it quits again. He isn't the most knowledgeable person. According to him the lights, engine and everything cuts off. There is no power anywhere. He just changed the $8 fusible link on the firewall and the problem still persists. He is out on the road and this is all the info I have. Any ideas?
  3. Oxbow
    Oxbow Road Train Member
    12,701
    131,097
    Nov 24, 2015
    There may be a main breaker in the battery box that is failing, or tripping correctly, and then re-setting itself. I am not sure about an IH, but many of the older trucks had one.
    bigguns Thanks this.
  4. kennry
    kennry Bobtail Member
    15
    Sep 4, 2015
    Follow the positive wire on the back of alternator all the way to the starter junction.there is a cluster of 3 wires that come together and there all the same size guage wire as alternator.they actual come together in the main harness that runs along oil pan on drivers side.one wire comes from alternator+,one comes from starter+and the last wire feeds positive to your fuse panel.all three are probably heavy corroded.this happened on my old 96 ih
  5. kennry
    15
    Sep 4, 2015
    Ask him if he noticed his volt guage has been charging on the low side lately..
  6. Heavyd
    Heavyd Road Train Member
    7,761
    6,201
    Feb 4, 2009
    If he is losing everything then I suspect a bad connection at either the starter or alternator. The main cab power feed for those is feed from either the starter positive post, or the alternator positive post and then runs into the cab. You could have some arching going on and once it burns out it goes open until it cools down and makes a partial connection again. Right at the fuse/breaker panel behind the passenger side glove box with where the main cable comes in and connects to a brass buss bar. Check all these locations and of course check the main batteries too. The cab grounds at both the left and right side firewall down to the starter and frame, so bad grounds are less likely since there are several paths, but make sure you check them too in case one has been disconnected.
    bigguns and running smooth Thank this.
  7. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    Could be the red wire on the battery.
  8. bigguns
    2,846
    6,853
    Jun 13, 2013
    Omega,GA
    Thanks for all the replies. It looks like I will have plenty to do trying to solve his problem.
