losing the wind noise/all noise in a century.
Discussion in 'Freightliner Forum' started by x#1, May 18, 2013.
  1. x#1
    x#1 Road Train Member
    1,773
    1,104
    Dec 24, 2009
    Cherokee County, Alabama
    constant battle as of late.i've tightened the door hinges,stuck the home type window tape all around sleeper door and both cab doors,and keep all the inner screws,well,screwed.HA! i keep all my cac and turbo clamps tightened.exhaust clamps stay snug.interior screws get snugged up.
    i realize that most is outside wind speed dependent therefore the wind noise dies down internally the less there is outside yet i want it quieter.
    any other suggestions? thanks
  3. leftlanetruckin
    leftlanetruckin Road Train Member
    3,607
    3,161
    Mar 12, 2009
    Mo Via Blackpool,Lancs.
    Home type window tape?
    If you want an improvement, get the OEM seals and start replacing them.
    Martin
    WorldofTransportation and x#1 Thank this.
  4. x#1
    1,773
    1,104
    Dec 24, 2009
    makes sense to me.the driver side door lock seemed to be off so i aligned it.the door seems to shut/open better plus it cut down on the noise.i'll look into the door rubber.thanks
  5. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Check car stereo retailers or websites for Dynamat or some similar insulation to cut down on rattles and wind noise. Inside door skin, roof, floor, etc.
  6. Smellfunny
    Smellfunny Road Train Member
    1,445
    967
    Jan 28, 2012
    South Carolina
    Check your door hinge as well. I bet it is wore out. Part is about 65.00-70.00 area.
  7. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    Every Columbia/Century I have seen comes from the factory with the door out of alignment top to bottom. Get some torqux bits, loosen the hinges, and bring the top and bottom of the door even with the cab, then adjust the striker. You will be pleasantly suprised at the noise difference. Pull the whole door in as much as you can and still get it to close fairly decent.
    Also, the windshield surround comes loose on these trucks, and needs to be resealed. Check that also. It can make a loud wind noise too.
