Losing throttle response
Discussion in 'Western Star Forum' started by Tanglefoot T 600, Dec 6, 2016.
  1. Tanglefoot T 600
    Tanglefoot T 600 Bobtail Member
    I have an 1991 kenworth T 600 N 14 460 hp the problem is I lose throttle response it goes to idle for 8 to 10 seconds then works fine again seems to be worse in very cold weather-10 C also has been triggered by jake switche but not always. Sometimes you have to shut off key to rectify
  3. boneebone
    boneebone Road Train Member
    2,297
    2,371
    Mar 13, 2009
    If your N14 has Electronic Controls, it could be a worn out Accelerator Pedal or a bad Accelerator Pedal Position Sensor.
    Those parts also affect the operation of the Cruise Control and the Jake Brakes.
    Tanglefoot T 600 Thanks this.
  4. W900AOwner
    W900AOwner Heavy Load Member
    714
    1,284
    Jul 2, 2014
    How often does it do it...every day/frequently? Hard to tell anything without knowing the frequency of the problem.
  5. Tanglefoot T 600
    It can happen 4 or 5 times then nothing for a month then 3 times in 15 minutes then nothing till the next day then about 15 times in an hour depending on wind and temperature
  6. W900AOwner
    714
    1,284
    Jul 2, 2014
    That really just sounds like a bad connection in a harness from the ECM to the firewall. Needs a thorough checkup of it every inch. All it takes is ONE corroded pin in one plug to act that way.
    The other thing I'd go to first is the TPS (throttle position sensor) wires at the accelerator pedal. I've had a couple of them fail and do that exact thing. The loop from the TPS itself to the end of the plug on the floor can fail, a broken wire, corrosion, etc. Salt from shoes plays havoc on them (if you're in that region where salt is present anyway.)
