Loss of air on 2013 cascadia DD 15 while driving?
Discussion in 'Freightliner Forum' started by Ralph 30, Apr 2, 2016.
  1. Ralph 30
    Ralph 30 Bobtail Member
    While driving my truck loses air pressure at a rate of approx every 4 and a half minutes. Both air gauges go down then compressor kicks in and air dryer blows off when back up to normal air pressure. Does not occur when sitting and idling.
  3. Animosus
    Animosus Heavy Load Member
    715
    2,807
    Dec 7, 2015
    SE Wyoming
    Does it only leak in high range?
    Ralph 30 Thanks this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,295
    Apr 9, 2009
    Humboldt, Sk
    Are you new to the truck, has it always done this or is this a new occurrence?
    My 2013 has about a 6 or 7 minute cycle since new. The 2010-2012 model engines ( mine was built in 2012) have an air powered DEF pump that uses a fair bit of air. Less when parked. The 2013 model year and newer ones use an electric pump.
  5. Ralph 30
    I have had the truck since new. This ordeal started a couple of months ago. I put a new governor and air dryer on it. Also needed a new fan hub assembly, so we know it isn't that. The air bags are good so yes we are thinking it might be the DEF system. My DEF system does use air. Gonna have to check the air pump.
  6. Ralph 30
    I will have to check that out. Never thought of that.
