Loss of power and acceleration lag
Discussion in 'Ask An Owner Operator' started by thecubantrucker, Aug 9, 2020.
  1. thecubantrucker
    thecubantrucker Light Load Member
    149
    92
    Jun 2, 2019
    ok guys freightliner century detroit 12.7 so my rpm,oil pressure, water temp went out they seem to be working intermittent wherever they want aslo noticed that my truck literally takes 4-5 seconds on lagging when accelerating and major loosing power going uphill no matter if it is small or big any ideas also no ecm codes
  3. kimbosa
    kimbosa Medium Load Member
    524
    351
    Jul 4, 2011
    lufkin texas
    IT MIGHT BE TURBO, ANY BLACK SMOKE?
  4. thecubantrucker
    149
    92
    Jun 2, 2019
    no black smoke at all this really got me messed up lol thinking
    kimbosa Thanks this.
  5. bad-luck
    bad-luck Road Train Member
    3,359
    6,211
    Nov 16, 2013
    Baltimore, Maryland
    Do you have a boost gauge? Are you building boost. May have a leak in your charge air cooler.
  6. thecubantrucker
    149
    92
    Jun 2, 2019
    air cooler brand new about 2 months ago boost Gauge shows I do boost normal but my acceleration and boosting lags about 5 seconds before I go to my peak 28pnds boost
  7. bad-luck
    3,359
    6,211
    Nov 16, 2013
    Baltimore, Maryland
    OK, Even though it is brand new one of the hoses could split or have a pinhole. when you say lagging are you talking about the Turbo spooling up? Also I would make sure that your air cleaner is clean maybe even put a new one in change your fuel filters. Start with the places that are the cheapest first
    frito bandito Thanks this.
  8. thecubantrucker
    149
    92
    Jun 2, 2019
    yes spooling up and well if I floor the pedal to the ground truck won't accelerate right away it will take 5 seconds slowly gradually accelerating and for thr turbo spooling up as well i checked all hoses clamps everything and nothing they were new as well
  9. Spyro2112
    Spyro2112 Medium Load Member
    609
    414
    Mar 17, 2018
    Actuator on turbo
    nikmirbre Thanks this.
  10. bad-luck
    3,359
    6,211
    Nov 16, 2013
    Baltimore, Maryland
    You can probably can build one yourself but mechanics have a tester that they charged the cold air system to about 40 pounds and check for leaks that's the best way to check it. Are you blowing black smoke out of the stack?
  11. thecubantrucker
    149
    92
    Jun 2, 2019
    wouldn't that trigger a code
