Loss of traction at speeds of 40-65...
Discussion in 'Experienced Truckers' Advice' started by Driver 222, Mar 2, 2023.
  1. Driver 222
    Driver 222 Bobtail Member
    On a certain hwy US 287 NB South of fort Worth Texas, during wet conditions, tractor spins out when pulling at speeds of 40-60. Truck feels like it's fixing to jack knife. I let off throttle and it straightens out. During acceleration, it spins out again. This has happened three separate times with three different sized loads. Light (1k or less), Medium, and heavy. Pulling 53' dry van. Tires are near new, and inflated between 90-100psi. So what's going on?
  3. Mnmover99
    Mnmover99 Light Load Member
    248
    343
    Oct 22, 2022
    Your truck has more torque than traction.
    bzinger, tscottme and Numb Thank this.
  4. xsetra
    xsetra Road Train Member
    5,132
    7,031
    Aug 21, 2011
    hy·dro·plane
    /ˈhīdrəˌplān/
    verb
    NORTH AMERICAN
    gerund or present participle: hydroplaning
    1. (of a vehicle) slide uncontrollably on the wet surface of a road.
      "a motorist whose car hydroplaned and crashed into a tree"
    2. Could be the road has a different mixture of asphalt and the oils surface when it gets wet. Leaving a thin film of oil over the water and road. Causing the same as 1 above.
    tscottme Thanks this.
  5. lester
    2,920
    7,890
    Jan 2, 2012
    NW, Iowa
    Is it a single drive axle with a dummy axle?
  6. Driver 222
  7. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    902
    1,751
    Dec 15, 2021
    What brand of tires do you have?I run on 287 a lot,some places will get slick when it rains.It does that out in Odessa also.
    If your trailer tandems are too far forward it can also take too much weight off your drives,there are a lot of things that can cause tire spin.
    4wayflashers Thanks this.
  8. Moosetek13
    Moosetek13 Road Train Member
    14,760
    18,603
    Nov 1, 2010
    Burnsville, MN
    The same stretch of highway in similar conditions causes you to lose traction.
    What is going on is you are learning the road and where to take it real easy.
    If you are paying for the tires, maybe you should pay more for better tires.
    If the company is paying, then learn to deal with it.
    That's why, as a company driver, I shut down at the earliest sign of poor traction conditions.
    The tires on these trucks are not designed for those conditions.
    tscottme, lual and 4wayflashers Thank this.
  9. Ridgeline
    22,487
    118,236
    Do you have air suspension?
    I had a truck with a tag axle that had bags that were over inflated.
  10. 4wayflashers
    4wayflashers Road Train Member
    1,066
    1,235
    Mar 14, 2014
    If it’s only on that section of road and doesn’t happen anywhere else, it’s going to be the road. Roads can get what’s called ponding during a rain and that just means water pools up or puddles up on the road surface.
    Interstate 40 does this between durham and Greensboro in NC. There’s multi vehicle pileups on that stretch all the time.
    I like to slow down when it rains. Mostly because others dont and they’re driving reckless. But also because it can be hard to see the ponding and id rather not wreck trying to race to the inevitable stopped traffic ahead.
    “Open shoulder tires” can help in rain and mud and snow but you’ll get a decrease in MPG.
    Hammer166 Thanks this.
  11. 201
    201 Road Train Member
    12,466
    25,485
    Apr 16, 2014
    high plains colorado
    What are you going 60 mph in the rain for anyway?:dontknow:
