Lost all power to sleeper and interior lights 2017 579.
Discussion in 'Peterbilt Forum' started by Arctic_fox, Jan 3, 2022.
  1. Arctic_fox
    4,080
    21,165
    Sep 16, 2016
    So i left my truck and apu off for about an hour and went inside to get in my shower. Came out and none of my sleeper lights work. Truck starts fine and shows 14V though was at 12.2 when i first started it, it had no LVD message however. I let it idle for about an hour thinking the voltage was low anyway then went to check my fuses and nada. All the fuses in the bunk colum look fine and i checked the sleeper fuse under the dash and they appear fine.
    Any idea whats going on? My only solution is bad batterys even though they are less then a year old.
  3. LoSt_AgAiN
    LoSt_AgAiN Heavy Load Member
    764
    3,844
    Sep 7, 2018
    Do you have a battery cutoff switch?
  4. Arctic_fox
    4,080
    21,165
    Sep 16, 2016
    Not that i can find. Tried pulling the terminals and cleaning them now as well.
    LoSt_AgAiN Thanks this.
  5. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    855
    1,666
    Dec 15, 2021
    Does the apu work?If not reset the gfi plug in on it.
  6. Arctic_fox
    4,080
    21,165
    Sep 16, 2016
    APU and espar work fine. Only things that dont are lights, 12 volt sockets, and fridge.
  7. IH Truck Guy
    4,343
    49,697
    Mar 2, 2008
    Purgatory
    If your truck has a low voltage cut-off,the first thing it kills is the bunk area.
    Starting the truck would've corrected that.
    So either you have a bad cut-off relay or a different problem
  8. North Pole Nightmare
    855
    1,666
    Dec 15, 2021
    Lost all power to sleeper after LVD - 2016 579
  9. North Pole Nightmare
    855
    1,666
    Dec 15, 2021
    I found this earlier thread,might be your problem,fuse
  10. Arctic_fox
    4,080
    21,165
    Sep 16, 2016
    Yup that didnt fix it. I pulled and replaced every single fuse with fresh just to be sure and am now traceing the wires. Im out of ideas lol
  11. Siinman
    Siinman Road Train Member
    5,289
    13,391
    Mar 5, 2017
    Kansas City, MO.
    That sucks man. One more bull sheet thing to deal with on that truck.
    Last Call Thanks this.
