Loud boom and billowing smoke need help diagnosing
Discussion in 'Trucks [ Eighteen Wheelers ]' started by ddixson, Jun 15, 2022.
  1. ddixson
    ddixson Bobtail Member
    41
    28
    Jul 10, 2012
    Mid Tennessee
    Ok, not a newbie but gonna sound like mine. Series 60 Detroit 99 I think, just had elbow and flex pipe replaced on rear exhaust. Jd oil in the morning but was a little off. Drove 50 miles to load, got loaded and 2 miles down the road I heard a loud boom by the fifth wheel somewhere like I blew a bag so I stopped and so much grey smoke was billowing out of the back of the cab underneath that I couldn’t see anything and it was I the truck . I thought it was on fire so I went and turned off the engine and it finally stopped. Now there No oil, no remnants of oil, a few spots on the rusted manifold but nada. Boss thinks I made it up and let it seize up by not checking it. I check it every morning. Any ideas? Mechanic can’t get to it for several days to diagnose. Thanks
    Btw…The boom was so loud and there was so much smoke that someone the hwy emergency breakdown guy
    Rideandrepair Thanks this.
  3. DUNE-T
    DUNE-T Road Train Member
    7,020
    17,079
    May 10, 2015
    Detroit, MI
  4. ddixson
    41
    28
    Jul 10, 2012
    Mid Tennessee
    Smoke was grey and was from the base of exhaust. He said turbo was fine and power was there before loud boom.
  5. Arctic_fox
    4,374
    23,850
    Sep 16, 2016
    Im going to say you either blew a turbo or one of the clamps came loose.
    Rideandrepair and ddixson Thank this.
  6. ddixson
    41
    28
    Jul 10, 2012
    Mid Tennessee
    He says I’m making up all of the smoke and that I haven’t been checking the oil(I do daily) and that I let a ten gallon oil reservoir go dry and that’s what did it. Would’ve had to leaked out in 50 miles and engine was ok power wise. It’s a real old truck but seemed to run ok to the pickup. Thinking his exhaust guy found something and he knew it was a rebuild so he let it blow up on me so he can say it was something I did.
  7. lester
    2,935
    7,940
    Jan 2, 2012
    NW, Iowa
    Blew something in turbo, truck started running on engine oil that the turbo was spewing back into the intake of the engine.
  8. Big Road Skateboard
    6,721
    37,838
    May 2, 2021
    Blew CAC boot would be first thought
    mtoo, Rideandrepair and ddixson Thank this.
  9. ddixson
    41
    28
    Jul 10, 2012
    Mid Tennessee
    So turbo would explain oil loss but gray smoke? Why on bottom of exhaust? Thank you all so much,
  10. SmallPackage
    5,700
    18,214
    Dec 20, 2019
    Marion Texas
    If the engine leaked out 10 gallons while running down the road the under carriage and chassis would be dripping wet and slick with oil. If turbo blew it is going to burn what oil it can and pump the rest out the stack.
  11. Trucker61016
    Trucker61016 Road Train Member
    1,433
    4,256
    Sep 18, 2017
    Linville, Va
    Did it smell bad too ???
