Loud noise like a rod or a piston when driving interstate speeds.
Discussion in 'Ask An Owner Operator' started by What's Next, Nov 16, 2021.
  1. What's Next
    What's Next Bobtail Member
    The engine is pretty much rebuilt. The transmission is new, and it's still making the noise. Between 60-65 it sounds like the motor is going to throw a rod or something. However at about 73 it's so smooth and quiet.
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    SO When you mention the transmission is new and its still making the noise, Im guessing you replaced the transmission thinking you had a trans problem? Who is the guy that just swapped it out to hope the noise was in the trans without checking? so anyhow, new trans and same noise, Varies with speed as you say, Rod knock sound, Check your carrier bearing and pinions and angles. Start there
    Magoo1968 Thanks this.
  4. abyliks
    abyliks Road Train Member
    3,895
    9,110
    May 2, 2010
    ludlow MA
    What engine? Because that’s pretty much exactly what an isx Cummins is supposed to sound like imo
  5. NYStarcar
    NYStarcar Light Load Member
    249
    595
    Oct 6, 2020
    In a van down by the river
    Don379 is on the right path. Check the rest of the driveline. A simple thing like a u joint can cause that kind of issue.
    Vampire Thanks this.
