Want to add when checking the tube coming out of the tubo thats where those boots are follow that tube towards the radiator. Theres where ur c the csc.
Loud turbo whistle/whine when when motor is under load!
Discussion in 'Volvo Forum' started by Volvo24, Aug 11, 2013.
Page 2 of 3
If it's a boost leak then shouldn't the loud whistle noise always appear? there's no noise if I drove without the trailer but only when I'm pulling something.
if the truck isn't running/pulling badly,then perhaps the turbo is working properly especially since you installed a new turbo. i've been around trucks when that happened.i love to hear the turbo.did the boost increase after instaliing the new turbo?
I'm not sure about the boost increasing but I don't thi k it did. But the truck pulls and performs very nicely. It's just the loud whistle sound that appears sometime gets me thinking if something is wrong.
my turbo got loud after changing one of EGRs..
turned out to be loose clamp/hose between AIR FILTER and TURBO on turbo sideRawze Thanks this. -
that a boost leak no doubt, also when the VGT actuator starts acting up you will get s whistle not as loud as a boost leak though
still could be the csc or boots I just had a new turbo and it did the same as yours. it would whistle under a load ck forcracks on that csc tube.
Jerzy Thanks this.
Hope the after cooler is not leaking..
Charge air cooler hose. It wont do it bobtailing cause its not working hard. When you hook up the trailer the turbo is boosting more. Take it off clean it and check it. Just a couple of clamps on it.
Page 2 of 3
