Low air problems on a 2004 Volvo 670
Discussion in 'Trucks [ Eighteen Wheelers ]' started by scsapril69, Nov 17, 2011.
  1. scsapril69
    scsapril69 Bobtail Member
    7
    Feb 4, 2010
    Eden NC
    Air compressor went bad, oil in tanks. Replace with reman compressor, new governor, new air dryer, cleaned tanks and air hoses.
    The problem is that from 0 to 70 pounds of pressure all tanks fill fine at idle. Accelerate motor to 1500 rpms all tanks fill slowly to 120 psi. When I let truck idle back down to 600 rpms, the primary tank drops to 70 psi within 90 second. The secondary tanks hold their air for a while then eventually drops to 90 to 100 psi.
    I have checked for air leaks with the truck off and had assistance checking for air leaks while holding the brake in. Results, couldn't hear any.
    While driving, my truck holds air at 120 psi and while in stop and go traffic or a stop light the same thing happens as I described earlier to the primary tank.
    Can someone give me some insight to this annoying problem.
    Thank you!
  3. Heavyd
    Heavyd Road Train Member
    7,773
    6,211
    Feb 4, 2009
    Still have a leak somewhere. Some leaks are so bad they make no noise. Keep looking.
    scsapril69 Thanks this.
  4. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    leaking brake chambers? have you listened for air leaks with engine off?
  5. bender
    bender Road Train Member
    2,105
    1,356
    Jul 20, 2010
    Don't Kid Yourself
    Is your main air line off the air compressor hard piping or a braided stainless flex line?
    Keep in mind that the check valve between primary and secondary air tanks has a rubber seat and can be affected by oil in the air system (swelling and deterioration).
  6. Kansas
    Kansas Road Train Member
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Grab a bottle of soapy water and start looking for the leaks. Listening only gets you so far.
  7. scsapril69
    7
    Feb 4, 2010
    Eden NC
    Thank you all for your responses. The problem turned out to be, my turbo actuator was leaking air.
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    mine did that too, I only found it because I tried to hear leaks while it was running, which you would think would not be the thing to do.
  9. Kansas
    2,541
    2,585
    Apr 14, 2009
    aircap, Ks.
    Ouch $$$$$$$$$. Did you have to buy a new actuator or was there a repair kit for it? Mine is doing the same thing, ive just been putting it off.
