Low boost with spikes
Discussion in 'Ask An Owner Operator' started by Lepton1, Sep 5, 2018.
  1. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    My brother runs a C15 CAT. Normally at Max boost he is at 28 psi. Recently it will only put out 9 psi, BUT will occasionally spike to 28 psi. He replaced both fuel filters and the air filter and the problem continued.
    Any ideas why this is happening?
  3. Espressolane
    17,720
    108,957
    What year is the engine.
    Lepton1 Thanks this.
  4. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
  5. Oldironfan
    Oldironfan Road Train Member
    5,777
    5,543
    May 22, 2017
    Is turbo toasted??
  6. nikmirbre
    nikmirbre Road Train Member
    5,441
    9,869
    Jul 27, 2011
    High Point NC
    Boost pressure sensor?
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    I'm no mechanic. But I would have to question the sensor too. Even his "normal" pressure seems low. I've got an 05 C13 that runs about 35psi. And an 07 C15 that peaks near 40psi. Both are factory as far as I know.
  8. Espressolane
    17,720
    108,957
    I would be looking at 3 or 4 things.
    First, is the turbo getting ready to implode.
    Time to check the bearings and turbine for play and damage.
    If memory serves me, I think this has a VGT. Could be a bad or sticking actuator.
    Sensors and wires
    CAC and connecting parts for leaks
    Last would look for an exhaust manifold leak or cracking around the mount flange
    The boost pressure seems low at all times. Makes me think leaks or no turbo rpm
    Usually I had 42 lbs at 1500 rpm. Also was set at 550.
  9. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    He replaced the turbo about three years ago. No visible cracks (like the last one that went).
    Oldironfan Thanks this.
  10. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    I am not going to address metallurgy. It's the cracks you cannot see you should be afraid of.
    If you have a tired turbo that wont get up and blow... something is wrong. Maybe the whole thing is sick and ready to blow. (Ha....)
    IF you cannot feed it air it cannot boost it right? How is the inbound air connections doing on that engine? The clamps etc. Is it a nice tight clear system with good filters to breathe?
    Anything else I don't know enough about turbos to really matter here. Those things are so important and vital you have to have a shop or someone who knows what they are doing to really look it over, even if it has to come off the engine and be really looked over.
    Lepton1 and Oldironfan Thank this.
  11. Oldironfan
    5,777
    5,543
    May 22, 2017
    I've blown apart a turbo. It's not good.
    Lepton1 and x1Heavy Thank this.
