Am routed to Houston going down US59 from Texarkana and see 2 locations with 13'6" at
Lufkin and Shepherd. Are these clearances okay for 13'6" truck ?
Thanks for your help
Low Clearance TX US59
Discussion in 'Questions From New Drivers' started by albert l, Oct 26, 2013.
Page 1 of 3
Yes they are.Most bridges for trks have 13"6" clearance.What I mean by most is some clearances for trks are higher then 13"6.
albert l Thanks this. -
US 59 is a regular truck route from Texarkana to Houston. There's a few truckstops down thru there also.
those bridges are railroad tressels, and when a train is on them, they are NOT 13'6".... you will see the signs telling you to go around.
just came through there last week. ran 59 Texarkana to Houston twice down and back with no issues
Make sure you take the loop around to avoid the lower bridges on the business routes. Meaning follow US 59 signage and avoid business routes.
albert l and flyingmusician Thank this. -
Same here--I remember the low clearence and bypass signs--but me thinks the rebuilds and ongoing construction thru there has eliminated them anyway
construction isn't complete yet......if i remember correctly think one of them has an overheight detector and signed work around if you set it off. doesn't look like much more work at one of those bridges and the new road will be done
Don't know until you try
Yes
No
Maybe so
I once bounced over new pavement and made a sky hole on a 13 7 sign just north of Seymour in on 31
Duuuucccctttttttt ttttaaaaaaapppppppeeeeeeeeeeeeeealbert l, Chinatown and Charli Girl Thank this. -
There's a decent sized new truckstop on the south end of Lufkin I think?
Page 1 of 3
