low coolant sensor
Discussion in 'Ask An Owner Operator' started by turner2955, Oct 8, 2018.
  1. turner2955
    turner2955 Bobtail Member
    30
    Apr 7, 2018
    the low coolant sensor light comes on causing the engine warn light to come it's full of coolant could the sensor be going bad
  3. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
  4. Accidental Trucker
    Accidental Trucker Road Train Member
    3,364
    7,391
    Jun 4, 2015
    T680? Known issue....
    SteveScott Thanks this.
  5. xsetra
    xsetra Road Train Member
    5,131
    7,025
    Aug 21, 2011
    Your harness could be going bad also. Corroded terminal ends.
    Accidental Trucker Thanks this.
  6. SteveScott
    SteveScott Road Train Member
    4,897
    16,807
    Nov 10, 2015
    If it's a T680 this happens frequently. You can unhook the plug from the bottom of the sensor to keep the warning bell from driving you crazy until you get around to replacing the sensor. The engine light will come on when you pull the wire. Just make sure you tie it off well so the plug doesn't rub on a belt.
  7. AlexanderK
    AlexanderK Light Load Member
    156
    95
    Mar 11, 2017
