Low coolant sensor
Discussion in 'Kenworth Forum' started by Up74427ca, Apr 12, 2014.
  1. Up74427ca
    Up74427ca Light Load Member
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    Hi,Driver,I drain reservoir ,put new sensor in,but the check engine keep buzzing,any help?
  3. wonderdog24
    wonderdog24 Medium Load Member
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    You have a short in the wiring.... Peel back the condom covering the wiring n search for the bare spot where they are touching.... What engine do you have???
    Up74427ca Thanks this.
  4. Up74427ca
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    I have isx cummin,thanks
  5. Up74427ca
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    Do I need to bring dealer to rest it?
  6. wonderdog24
    377
    127
    Mar 1, 2012
    Puyallup,Wa
    All depends on how you read active codes vs non active codes... I only run Detroit s60... Active goes away once fixed
  7. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    Once you find and repair the problem the light will go out after running the engine for 30sec. Or so. What are you using to read the codes?
  8. Up74427ca
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    I took it ta truckstop at Troy,Il,they put in my ,they deleted but 3 second later,it pop up again,they told me to bring to kw dealer,my default code said low coolant,but I changed it,but it buzzing,it drive me nut,I thinked when I get home ,I will bring it in kw dealer ,but I trace wire,no damage....
  9. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,144
    Apr 1, 2011
    Broomfield, CO
    Wiring issue. They've had a fair number of those with the wiring harnesses they use.
  10. Up74427ca
    145
    25
    Sep 1, 2012
    Little Saigon,ca
    Thank you,Witchinghour,hands down to Witchinghour...
  11. Myoneload
    Myoneload Light Load Member
    218
    45
    Jan 22, 2013
    around here
    Just put the coolant about a half inch above the hot line and it will quit..
