low oil pressure in 2007 isx
Discussion in 'Peterbilt Forum' started by 388petedh, May 27, 2011.
  1. PeteVolvo tech
    PeteVolvo tech Bobtail Member
    33
    12
    Mar 23, 2012
    WI
    First off you need to take it to a shop. They need to go through the low oil press tree. They will measure oil press before and after the filter. I would say your most likely failure is the sensor, we have changed many of them. If your filters are truly plugging most likely your injector timing is retarded. This is a major issue that Cummins just figured out in the last year or so. To check injection static timing takes about 4-5 hours depending on chassis. If it is bad it will take 8 or so additional hours to fix depending on chassis. This is a major issue on CM871 07-10 engines (egr&dpf no DEF). This issue also gives you poor throttle response, poor fuel milage, plugged dpfs, and more.
    Also to inframe a ISX cost $35,000? guess our shop needs to charge more normally a basic ISX inframe runs around $15,000 even less if you reuse the head which most of the time you can.
  3. Dino1968
    Dino1968 Light Load Member
    Could another possibility be fuel in the oil?
  4. PeteVolvo tech
    33
    12
    Mar 23, 2012
    WI
    Enough fuel to cause low oil press warning light and codes would be very noticable on the dipstick. Most likely the oil filter is plugged or the sensor is bad. I found another plugged filter today.
  5. country29
    country29 Medium Load Member
    518
    157
    Feb 27, 2010
    could you pm me this information on inj timing issue? I work for a large fleet with mostly cummins isx and we have seen particularly in the petes we have but starting to see in the prostars, oil filters clogging around 12-15k on pm. I'm not totally in the loop like I use to be when I worked at a dealership but would like to know more about this, and what cummins is saying about it. are the cam gears slipping or ? thank you in advance.
  6. PeteVolvo tech
    33
    12
    Mar 23, 2012
    WI
    Hello, It is not a issue of cam gears slipping. If you are familuar with Isx timming you know the injection timming is set using a wedge and proceedure to line the crank to the cam using a tapered cam gear. What it comes down to is it is not exact enough for these engines. If your wedges are worn, parts machined slighlty diffrent, or don't follow the proceedure completely the timming will be off and most of the time its retarded. Cummins now has a tool to measure static timming just the same as we used to do with a N14 to set rocker box shims. Cummins has relised 4.25, 4.5, and 4.75 wedges to advance the timming as needed. As of right now all the CM871 ISX problem engines ( plugged oil fiters, plugged dpf and doc, low power/sluggish) I have measured static timming on have been retarded. If you have access to Cummins quickserve you can look up static timing specks by engine CPL. Also the proceedure is listed under injector static timming.
    country29 Thanks this.
  7. maxicruise
    maxicruise Light Load Member
    58
    19
    Aug 11, 2010
    Illinois
    Country29, is this a problem with the donaldson filter only? And are there any differences in the micron size on these filters? I'm wondering if other manufacturers engines are seeing the same issues, just not as bad? Seems to me from what I have been learning, that this extra soot in these EGR engines is causing a whole lot more problems then has been let on before. Thanks for the info.
  8. country29
    518
    157
    Feb 27, 2010
    the donaldson filters are the only ones the cheap &^%*$#@ I work for want to use. I have tried talking them into doing some test trucks but no dice, and they want to run dino oil 36k before service, they ran synthetic 50k but we did a filter change @ 25k but they found out it was pitting some of the cams and rocker rollers, go figure. then they went to a 36k interval and we started having low oil press issues out of some trucks but not all, thats what is puzzling. I have talked to people that use different filters and are having the same issue, dont really think its a filter thing, I think it is a isx thing combined with a long pm interval. and yes their is more soot in these things than has been let onto before.
  9. country29
    518
    157
    Feb 27, 2010
    does quickserve list the part # for the tool also? thanks
  10. PeteVolvo tech
    33
    12
    Mar 23, 2012
    WI
    Sorry for the delayed response, If you have access to Quickserve here is the link to the proccedure. https://quickserve.cummins.com/qs2/pubsys2/xml/en/procedures/10/10-006-025.html If you do not have access the tools needed are 3824942 and 2892426. The proceedure is very much the same as shimming cam follower boxs on a N14 for injection timming. Just you use diffrent wedges instead of shims.
  11. sinnano7
    sinnano7 Bobtail Member
    11
    Oct 10, 2013
    sensor,filters,pump,or,spun,bearing,....in,order,of,serverity..
