low oil psi after recent inframe/ excessive blow by
Discussion in 'Freightliner Forum' started by junior99, Oct 19, 2014.
  1. junior99
    junior99 Bobtail Member
    7
    I have a 99 classic w 05 crate engine.. it recently had inframe done. But I've noticed great deal 9 oil consumption and blow by like freight train... ?? Oil psi is under 40 running down hwy 3 days after svc was done... can anyone help??? 60 series detroit. Shop was recommended by company I run for. And purchase ing trk thru..
  3. chalupa
    chalupa Road Train Member
    3,757
    1,643
    Jul 22, 2010
    Houston,Texas
    You didn't say what engine...or who did the in frame ...or who did the oil change and with what......You didn't say what is a great deal of oil consumption either........
    Need more info......but if it's as dramatic as you say then you better hit a trusted shop ( now) for an evaluation or you will do the inframe again.
    JMO
  4. junior99
    7
    Sorry bout that new this site
  5. wore out
    wore out Numbered Classic
    16,069
    194,624
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Regardless of what engine it doesn't sound good
  6. junior99
    7
    I kinda new that something was wrong . But I went off just info I was given but I'm too far into paying for just too give back now.
  7. snowwy
    snowwy Road Train Member
    20,564
    13,288
    Jul 6, 2009
    blowby comes from worn piston rings, oil consumption is another sympton.
    how recently was your inframe? cuz it's defenitly time for an inframe. AGAIN!!!!!
  8. Powder Joints
    7,702
    7,822
    Sep 25, 2007
    Rosamond, SoCal
    they installed new rings on your old pistons, did not change the liners, sounds like the bearings maybe wrong also, ...
  9. junior99
    7
    just had a year cause the owner tell me the word you just got to run out. the shop give thems.one year or 100,000 miles
  10. tirednaz
    tirednaz Heavy Load Member
    838
    430
    Oct 4, 2011
    Arizona
    What's the name of the shop?
  11. junior99
    7
    and ongoing problem I took i tot his shop for him to check it out. We found a crack in the air to air. I replaced it !then be considered oil cooler may have a blockage. be done so Friday replaced it.
    first run out with it since the old crew is buddy. I have had enough time to tell if it's going to be use any. but the blow by still unreal.mI pick the truck up in April and it had blow by then I wasn't sure if that was right or wrong? that time frame was only 6 months old
