I have an issue with my electric power. 2011 prostar Cummins the gauge goes lower than 12 and light comes on while I’m driving then it goes back to normal after a while and it keeps doing that all day. 3 new interstate batteries and alternator isn’t more than a year old. What could it be? Thanks in advance!
Low power light goes on then back to normal
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cruisingkid, Sep 20, 2019.
Check all the grounds and make sure they are clean and tight.
If you have a master power switch check all those connections.Rounded_nut and Cruisingkid Thank this. -
Thanks I’ll do that; as of now I turned off my truck and it failed to start with the voltage at 11.8 and TA mechanics aren’t certified to jump start me.
If you have a meter,check the voltage directly at the batteries.
Some of the IH trucks had a fuse on the hotline in the battery box.
