low power no boost
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by berniesgonefishing, Jun 21, 2021.
  1. berniesgonefishing
    berniesgonefishing Bobtail Member
    hi everyone got a maxforce 11 2012 dump truck. problem is low power no boost.new egr vavle new air to air new hp turbo.the most i can get is about 2 psi of boost with load on it.starts perfect .check actuator on waste gate operates smoothly new air filters .any idea s thanks
    Trucking Jobs in 30 seconds
  3. Pa_Polarbear
    Pa_Polarbear Bobtail Member
    27
    26
    Jun 21, 2021
    Sounds like somethings clogged uphill or downhill. Check your exhaust side or air to air for rags or clogged dpf/muffler.
  4. ChuckMartel
    ChuckMartel Light Load Member
    100
    55
    Jan 22, 2021
    ^^ what he said. Also sometimes the wastegate in the HP turbo housing will not close fully. Make sure your exhaust back pressure valve is moving and not stuck closed, same with your engine throttle valve.
  • Draft saved Draft deleted
