Low turbo boost psi after overhaul - cat c15 2006
Discussion in 'Peterbilt Forum' started by alex.borys, Nov 16, 2016.
  1. alex.borys
    alex.borys Bobtail Member
    12
    7
    Nov 16, 2016
    Chicago
    Hi everyone. 10000 miles ago I just performed an overhaul on my cat c15 2006 (2005 manufactured) twin turbo at 980k. I used a platinum overhaul kit. After 1000 miles check engine came on and turbo pressure didn't go over 21 psi. Come back to shop, problem found - bad actuator from a dealer, changed. After I back to road I found that my turbo pressure is 28 psi at 1500 rpms at full throttle, what is too low (before that normal was @38 psi) and gage arrow was always shaking +- 2psi. Also when I press the pedal just a little at @10-15 psi boost I was hearing some whistling like an air leak, over 15 - nothing. Months before overhaul installed new itercooler. Week ago at my repair shop checked all system for air leaks - nothing found. Now I just stoped at the truck stop, shut down the engine for 30 min and came back to highway - something changed: my turbo boost doesn't go over 21 psi, gage arrow is stable and no more shaking, and boost pressure grows very slow, after I release gas pedal and then apply it all the way, I counted 7 sec from 0 to 20 psi boost pressure and I can feel that truck loosed power. Thanks ahead for any advices.
    KB3MMX Thanks this.
  3. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    Make sure turbo bolts are tight! also check your cac boots
    KB3MMX and alex.borys Thank this.
  4. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    A clamp or something is probably loose. And it's most likely after your turbo. Would be my guess anyway.
  5. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    Did you crack the bellows between the turbo and the pre-cooler? I'd check that if you have whistling.
  6. alex.borys
    12
    7
    Nov 16, 2016
    Chicago
    Last week my mechanic checked for leaks - everything looks good . They blowed air from intercooler entrance towards engine and then from intercooler entrance hose to air filter, all looks good at 100 psi. I'm not sure they checked the bellows. Thanks for suggestions!
  7. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I'm not a Cat guy, but if it doesn't have an air leak and the turbo is tight with a fresh gasket, it sounds like the ECM may be derating fuel. Do you have any codes?
  8. alex.borys
    12
    7
    Nov 16, 2016
    Chicago
    No, I don't have any codes
  9. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    Only other thing I can think of is maybe it's collapsing a boot on the intake side of the turbo. That also might explain the needle jumping around before.
    KB3MMX Thanks this.
  10. alex.borys
    12
    7
    Nov 16, 2016
    Chicago
    The clamp looks tight, but I'll test it. The only one thing I didn't test is probably exhaust, but looks like no leaks on pipe. Thanks!
  11. ShooterK2
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    If your intake boot has a spring inside, make sure it isn't broken. The intake will collapse that boot under heavy throttle.
    Aside from that, I'm out of ideas. Surely one of the Cat guys, like @wore out, will chime in soon.
