low voltage alarm bypass on 2013 t660
Discussion in 'Kenworth Forum' started by cliffo, Apr 7, 2014.
  1. cliffo
    cliffo Bobtail Member
    erie michigan
    can anyone tell me if a low voltage alarm will prevent dome lights from working if so can I bypass it
  3. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    The whole purpose of a low voltage shutdown is to leave you enough juice to start the truck. Start the truck and let it run a little. Then your lights should work. If not you have other problems like a fuse.
  4. Chris50
    Chris50 Medium Load Member
    346
    215
    Jun 21, 2010
    Florida
    yes, my dome lights and sleeper lights/outlets stopped working when i had a problem with the Low Voltage Disconnect system.. I bypassed it then a few days later found a broken ground at the batteries that turned out to be the original culprit..removed bypass....i have a freightliner so not sure anything is similar but in my fuse panel on dash is 4 posts with large red wires going to them...if you put a test light to these 1 will not have power, this one was powered by the low volt disconnect,run a jumper from one of the other 3 `hot` posts and you should be golden.....
    cliffo Thanks this.
  5. cliffo
    erie michigan
    circuit breaker good only .7 volts on dome light
    had same problem on different t660 and dealer bypassed low voltage and worked fine after that only need to bypass temp. for now any advice
