Lowering the 5th Wheel
Discussion in 'Ask An Owner Operator' started by BandBSowards28, Apr 9, 2018.
  1. BandBSowards28
    BandBSowards28 Bobtail Member
    29
    4
    Feb 27, 2018
    Hey all. So, I'm driving a 2015 Pete 579 with a 5th wheel that has a 51" height. I'd like to get it down to 47-48" as I am going to be hauling exclusively 53' vans and don't want "tilted trailer" syndrome even if it's only 3" as I know that may be 3" too much for some east coast bridges and will also adversely affect my mpg. Is there a way to lower my over all 5th wheel height without having to put on a set of shorter drive tires? Thanks!
  3. Brickwall
    Brickwall Light Load Member
    292
    381
    Jan 30, 2018
    There is, mentioned in the owners manual of my '11 386, a way to adjust ride height via the air suspension. That would be worth looking into. I've got tall everything and I'm riding at 49"
  4. BandBSowards28
    29
    4
    Feb 27, 2018
    I checked my owners manual and it appears there is a section that talks about adjusting the suspension ride height; however, it warns that it should only be done if absolutely necessary and only temporarily.
    Brickwall Thanks this.
  5. Brickwall
    292
    381
    Jan 30, 2018
    Ah ok. Might be worth bouncing into a pete dealer next time you see one then. 51" is tanker height. There has to be an easy/cheap way to drop it down a little. Sounds overinflated to me...
  6. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    You can change out risers on the 5th wheel. Holland makes a variety of heights for different applications. Just be carefull of your rear fender height so that trailer doesnt hit them.
    Brettj3876, Lepton1, Brickwall and 2 others Thank this.
  7. Long FLD
    Long FLD Road Train Member
    11,429
    46,231
    Mar 4, 2015
    I’d change the risers on your 5th wheel before I started messing with your ride height and getting things all out of whack.
  8. Twista89
    Twista89 Light Load Member
    86
    39
    Oct 2, 2017
    Want to swap risers?? I need to go up to 51in on my holland fifth wheel lol. Right now it’s at 47.
  9. Ezrider_48501
    3,845
    5,130
    Apr 2, 2011
    bismarck, nd
    changing the risers is the right way to do this if you change the ride highth of the air suspension your going to throw your drive line angles all out of wack
    MACK E-6, Roberts450, Long FLD and 2 others Thank this.
  10. Adamali21
    Adamali21 Light Load Member
    278
    179
    Jul 24, 2018
    What did you end up doing because I am having the same problem
