Lug Nut Torque
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Ken, Aug 22, 2008.
  1. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    I want to buy an impact wrench so I can remove my wheels without having to drive to the shop.
    Is a 1900 ft/lb impact wrench sufficient?
  3. kotflb
    kotflb Bobtail Member
    16
    That is way more impact wrench then you'll ever need on wheels. I own a 1200 ft/lb and it is more then I need, unless you have a lot of rusty bolts. You may need 1000 ft/lbs for removal on some of the more stubborn nuts, but the max torque on the hub piloted nuts are around 450, and 550 or 600 ft/lbs on the earlier budds. Double check those numbers on max torque bc its been awhile since I last looked them up.
  4. MedicineMan
    MedicineMan Road Train Member
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    any cheap 1" impact should do fine. about 1200ft pounds. remember with a 1" gun you need the larger 1/2" air line and fittings.
    personally I found a 3/4" impact gun that runs 1200 ft pounds and it works good on wheels and still uses a 3/8" line. I've broken loose stuck nuts that our old 1" gun couldn't
    goga Thanks this.
  5. Mechanic
    Mechanic Bobtail Member
    14
    4
    Aug 17, 2008
    Barstow, CA
    3/4 is easier on your back. 1200 ft lbs is good :)
  6. dray
    dray Bobtail Member
    7
    Aug 12, 2008
    McDonough georgia
    +1 too me a good 3/4 is alot better than a 1 inch, especially just for lug nuts
  7. Ken
    Ken Couch Commander
    1,768
    11,941
    Oct 29, 2006
    Thanks for the feedback.. It looks like 3/4 it is..
    I haven't seen any 3/4's with the long shank. Is there any problem reaching in with the standard size?
  8. 25(2)+2
    18,749
    45,388
    Sep 18, 2006
    the road less travelled
    If you can't find a long shank 3/4, get an extension. I doubt that there is a long shank one in a decent brand. The inlet is 3/8 inch but the hose size recommended is 1/2 inch.
  9. gearjammer-2000
    gearjammer-2000 <strong>Clutch User</strong>
    670
    205
    Dec 18, 2007
    columbus Ohio
    I have found out a high end 1/2 will also do the trick i got one from I/R [ingersall rand] and just out of curiosity i gave it a try, to my amazement it took them off, I also have 1/2 airline running to it.
    that gun made a believer out of me, no more discount air tools!!!
    goga Thanks this.
  10. MedicineMan
    5,799
    6,440
    Jan 13, 2007
    Woodville, TX
    I can reach them without an extension but I have 24.5's so I won't vouch for 22.5's
  11. cumminsvolvotech
    cumminsvolvotech Bobtail Member
    6
    Aug 23, 2008
    Denver, CO
    IR2141 is the best 3/4 impact out there!
